Unlevel 6" lift
Old May 25, 2013 | 09:09 PM
Hellspawns718's Avatar
Hellspawns718
Unlevel 6" lift
I just installed a 6" rough country lift in my 2006 crew cab.The truck is a work model basic everything.It sat high in the rear when it was stock.I asked rough country if it would be level when I lifted it and they said yes.It is not level.Just over 2" higher in the rear.It does not look bad but I would like it a little closer to level.Can I just add a 1" coil spacer? It is not a 4 link lift it just has arm drop brackets.Any help would be great! Thanks
Old May 25, 2013 | 10:06 PM
Ian123's Avatar
Ian123
You'll be fine with the 1" spacer. Either that or buy a smaller block for the rear.
Old May 25, 2013 | 10:18 PM
Hellspawns718
Oh good.I was not sure if the 1" rise in the front from the spacer would pull the wheels to far back or throw off the steering geometry.I don't want to get a smaller block in the rear.I want as much lift out of it as I can get.Thanks for the help.Now to find a 1" coil spacer.Any suggestions?
Old May 25, 2013 | 11:15 PM
Ian123's Avatar
Ian123
It will do both of the things you said but not to a noticeable amount. I have a 2.5" spacer and my track bar pulled the axle a half inch to the driver's side, but the truck still tracks straight. I got my spacers from Top Gun Customs, they were cheap and work fine.
Old May 26, 2013 | 06:47 AM
Hellspawns718
Cool thanks for the help
Ryan0214
26
Jan 27, 2013 07:36 PM
Bryanblaylock
Jan 17, 2013 04:40 PM
cbzdel
Nov 28, 2011 06:00 PM
Bluebronco85
1978 - 1996 Big Bronco
Sep 16, 2011 09:24 PM
fordguy300
Offroad & 4x4
Dec 1, 2008 10:17 PM
