Little tiny lift?
Front... rear... both?
Cheapest way is a shackle flip in the rear and lowering the coil buckets in the front, the only monetary cost to you is some grade 8 hardware down at your local Ace hardware store.
It is somewhat labor intensive though, a lot of work if you're only after an inch of lift, personally i wouldn't go that route unless i was looking to get 2-3 inches of lift.
Start to finish of how I did it .... good luck.
https://www.ford-trucks.com/forums/1...s-of-pics.html
The front springs are probably tired and sagging, if you just want to level out the front-end new springs are your best bet...
They'll set you back about $120 but they're a relatively easy two hour installation right in your driveway.
Before I pose this question/possible answer please do not try this untilit's come to a conclusion that this is a safe way to gain one inch of frontlift!
Has anyone put a metal spacer block between the radius arms and coil plates?
I can't see how this would be an issue but maybe I'm missing something. Obviouslystacking washers under the coil plate is NOT what I mean, but a solid platewelded to the bottom of the coil plate should provide the lift and bestructurally sound.
That being said... I'd opt for the new front springs to fix the probably saging original ones.
You can probably do it but it would be a PAIN.
