i checked my fuel pressure today..... turned key on and the gauge read 40 psi. i purged the air out of the hose at the gauge and it had the same reading. drove it to see if pressure would change but it droped down to about 38 psi
pulled in to the drive way shut the engine off and turned key back on and got 60 psi ???? turned key off then back on and again only got 40 psi on gauge. what am i missing or doing wrong? I'm confused and concerned
diesel Dan is corect.... I'm using a mechanical gauge.
i have been doing maintenance the last couple of weeks and this was on my list to check as i haven't installed one in the truck yet...
I'm hoping I'm doing something wrong as Ive got the annual camping trip next week end. does anyone have ant suggestions?
silly question???? should there be pressure after the key is cycled off?
i did the blue spring mod a few month back could i have missed/messed something up?
I have my sensor remote located so I had to " purge the air from the line " when I installed mine.
Gotcha' -- understand now.
To OP: did you install the whole kit? There's the replacement brass poppet valve and gasket. Also IIRC there was a thread where one of our members mentioned different fuel pressure regulators and if you didn't catch putting a certain o-ring in the FP would be off.
I'll see if I can find that thread and bring it back...
Here's the thread -- not a lot of detail on telling the different type FPRs. So we might could use some help from Mark (bismic), who's knowledge of all things 6.0. runs deep...
Never did find out when it switched. My '06 and a couple of others didn't have it. I did an '03 for a friend at work and his had one. Sorry I can't be more help.
If your gauge is a mechanical one with respect to not using an electrical signal to read the pressure ( like a bourdon tube style ) I would be concerned also, if however it converts an electrical signal from a pressure sensor I would suspect the sensor.
