Dome Light Is Not Working
Old May 24, 2013 | 04:40 PM
fordtruck661's Avatar
fordtruck661
Hi guys I have been fighting with my dome light not working. It will not come on with any of the doors open or using the light switch. I also always have the door ajar light on. I have tried spraying WD-40 into the door, replacing the bulb and checking the fuses with no luck.
Im not sure where to go from here.
Old May 25, 2013 | 08:25 AM
snknby123's Avatar
snknby123
I had issues with my courtesy and dome lights not working. My issue turned out to be the fuse box itself. Water had entered the cab down the door/windshield. I had to remove it and look very closely to see the black roasted circuitry. Look for signs of water down by your fuse box and GEM module. Google it and you will get lots of info with wiring diagrams etc.... good luck
Old May 25, 2013 | 06:13 PM
fordtruck661
Ok so stupid me I have been checking the wrong spot & fuse. So I found that the #14 fuse is missing (must have been removed from the previous owner) So now im changing my problem to all the light stay on all the time.
Old May 25, 2013 | 08:26 PM
carltonwebb's Avatar
carltonwebb
Apparently, previous owner had the same issue....Being a supercab, you only have two switches to check. One in each front door. I had a bad one in my drivers door. Being as how I do not have any power options anyway, i cut the wire in the door jamb to disable the light and the beeper when sitting when the door open talking to customers. My thoughts were that i could just roll the switch if i wanted the light from the drivers side.
I am not recommending it to you but it was my way of fixing the light and killing the beeper at the same time.
Old May 26, 2013 | 04:08 PM
fordtruck661
Well I took apart the door today and found the bad switch. The hard part was finding one. Called 3 different stores that did not have them and told me they could no longer get them. Finally found one and had them hold it for me. You could say the old one has seen better days.
Also does anyone know what the normal delay is for the lights to turn off?
Old May 26, 2013 | 07:57 PM
crop harvester's Avatar
crop harvester
the dome light on my truck in signature turns off in about 30 seconds.
Old Sep 4, 2013 | 09:06 PM
BoydGilley's Avatar
BoydGilley
Ok how did you get to the switch? I'm starting to get a problem with my driver side door, i can't roll the windows up until the driver door is closed. All i need to know is how to get to the switch. Thanks
Old Sep 4, 2013 | 09:51 PM
fordtruck661
You have to pull the inside of the door off and then unbolt the handle and the latch from the door. It sounds a lot worse than it really is. took me maybe 30 min.
This video might help you out.
cowboyup_63
Electrical Systems/Wiring
13
Aug 14, 2011 08:39 PM
ddeskin2
1997 - 2003 F150
Aug 25, 2008 04:01 AM
nickh829
Nov 15, 2004 02:06 PM
OAGES
Mar 10, 2004 10:12 AM
Mark156701
1983 - 2012 Ranger & B-Series
18
Dec 29, 2002 12:30 PM
