Sponsored by: Auxito
Door Ajar Light
Old Aug 24, 2008 | 04:39 PM
ddeskin2's Avatar
ddeskin2
Door Ajar Light
I have a 2001 F150. The door ajar light won't turn off. Along with the door ajar light, the back outside lights won't turn off. The only way I can get the light off is when the fuse is taken out. Then when the fuse is out, the power windows won't work. I have taken this to a mechanic and they are unable to find the problem. Any suggestions?
Old Aug 24, 2008 | 05:20 PM
torkum's Avatar
torkum
Just spray the driver door latch with WD40 and it will clean the sensor.
Old Aug 24, 2008 | 05:29 PM
triton_2002's Avatar
triton_2002
Don't go back to that mechanic......
If the wd-40 doesn't do it, or it happens again, you'll need to change the switch in the door.
Old Aug 24, 2008 | 05:34 PM
DGMFORD's Avatar
DGMFORD
I had the same issue, not on my truck, but my ford Taurus, and WD40 did the trick.
Old Aug 24, 2008 | 08:17 PM
kais's Avatar
kais
WD40 right in the door latch about once a year works for me. Lake Erie walleye fishermen used to spray the nightcrawler with WD40 as a fish attractant. Either way you can't lose.
Old Aug 25, 2008 | 04:01 AM
ncranchero's Avatar
ncranchero
Odd you should say that. Every time I pass a lake I find that fish are chasing me ............
Just kidding. WD40, Deep Creep, etc. should do the trick.
