Cargo light pad...
Old May 23, 2013 | 10:41 PM
alchemist1's Avatar
alchemist1
Cargo light pad...
I bought a new cargo light pad from LMC truck. It doesn't seal very well between the pad and the truck (it's ok between light and pad). There's almost a gap at the top where the pad is widest. When you try to tighten down the sheet metal screws, they are easy to strip and you end up having to use bolts/nuts.
Is the Dennis Carpenter part (OEM/Ford I think) a better fit and/or made from a stiffer rubber?
thanks.
Old May 23, 2013 | 11:01 PM
bucks77ford's Avatar
bucks77ford
The one I bought from DC worked great. I thought the cargo pad from LMC was just one from DC anyway. I think there is only one way for it to go on. I don't think you can put it backwards, but I can't remember.
Old May 24, 2013 | 10:31 AM
alchemist1's Avatar
alchemist1
The one I got from LMC doesn't 'look' like Ford. It was packed in a plastic bag and most of their stuff is from offshore (Taiwan/China).
I know I have it on right - there's only one way that it goes. May just have to put some sealant up there on the top edge/lip. any suggestions?
Old May 24, 2013 | 08:57 PM
bucks77ford
I'd try and send it back and get another one. If not, other than sealant maybe get some waterproof foam insulation and stick it on the back to seal up against the cab.
Old May 26, 2013 | 02:48 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Pad, utility lamp mounting
73-77 F100-350 before s/n Y60001 w/ cargo area light
D3TZ-13790-A
Dennis Carpenter, Concord, NC has 667 (704) 786-8139
Wesley Obsolete Parts, Liberty, KS has 4 (606) 787-5293
Antique Auto Supply, Arlington, TX has 1 (817) 275-2381
NOS Parts Source, Olathe, KS has 1 (913) 220-5746
bearhugger
Mar 19, 2013 08:39 AM
alchemist1
Jan 25, 2013 10:59 AM
2 stroke man
13
Feb 22, 2008 09:34 PM
LoneStarTrucker
Oct 6, 2007 09:26 AM
