Stock headlight replacement
Old 01-04-2016, 09:52 AM
EcoboostKev's Avatar
EcoboostKev
EcoboostKev is offline
I posted this in the Superduty section and didn't get a single response. I'm looking to replace my stock headlight assemblies and bulbs on my 2001 F350. Just looking for some advice on what's good and what to stay away from?
Thanks, Kevin
Old 01-04-2016, 10:08 AM
Baatzy's Avatar
Baatzy
Baatzy is offline
Not sure on whats good as I am still running stock with just some regular old headlights, but I am considering going to the 02-04 style headlight and putting in LED bulbs from lifetimeledlights.com. Guys over on the 6.0 forum have been giving good reviews of their lights.
Baatzy
Old 01-04-2016, 11:17 AM
Sous's Avatar
Sous
Sous is offline
Received 4,464 Likes on 2,853 Posts
This is what I bought, I see they are unavailable now, but I think they were listed on Ebay too.
They installed great, look great and I would get them again. I only wanted a cleaner/fresher look for the truck due to the old ones being hazy looking.
Amazon.com: Ford F-550 Super Duty/ Ford F-250 Super Duty/ Ford F-350 Super Duty/ Ford Exc...: Automotive Amazon.com: Ford F-550 Super Duty/ Ford F-250 Super Duty/ Ford F-350 Super Duty/ Ford Exc...: Automotive
Old 01-04-2016, 02:32 PM
holeshotwalt's Avatar
holeshotwalt
holeshotwalt is offline
Quick and easy is the 02-04 OEM housings (because the lens stays clear/ doesn't cloud like the older ones).
I had them, but elected to go with OEM 05-07 housings (just 'cause I liked the look). To my surprise, the light output is FANTASTIC compared to the earlier style. The combination of reflector/lens/bulb is really great, and being OEM, they don't leak or fog up.
Old 01-04-2016, 06:22 PM
EcoboostKev
Thank you!
Old 01-04-2016, 06:28 PM
EcoboostKev
Did you use your stock bulbs or Replace those too? Also was there a big difference in visability between the old and new ones??
Thanks
Old 01-04-2016, 06:35 PM
holeshotwalt
By the way, I bought my OEM ones off Craigslist with all bulbs, etc for $60 for the pair. I've also seen them at Pick n Pull.
Old 01-04-2016, 06:47 PM
EcoboostKev
Didn't even think to check craigslist! Thanks.
Old 01-05-2016, 09:16 AM
brian42's Avatar
brian42
brian42 is offline
Good to hear. I have a set of 05 lights in the garage waiting for me to install them. Did you get an 05 header panel or did you cut yours? A new header panel was not in the budget for the upgrade so I am planning on setting aside at least 1/2 day so I can take my time.
Old 01-05-2016, 10:13 AM
holeshotwalt
I just cut mine- took about 2 hours with a diamond Dremel cutter. If you have bigger saws, it'll go faster. Check the tech stickys for hints and pics...
You'll need an adapter pigtail (or replace the connector) for the different bulbs too. You'll love 'em!
Old 01-05-2016, 07:55 PM
jhl3's Avatar
jhl3
jhl3 is offline
Thanks, Kevin
While you are making your decision, spend $2 on a small can of Deep Woods Off w/ Deet. Spray it on, wipe it off x3....takes about 1 min per light and you'll be amazed at the difference it makes with the old lens.
Old 01-05-2016, 08:11 PM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,897 Likes on 1,145 Posts
The best light you can get is from '02-04 lenses with relay harness and 100/80watt bulbs. More usable light than any retro HID and without annoying other drivers.
'05-07 lenses use crappy H13 bulbs and frankly the optics just aren't as good. Besides, it makes the truck look like a 6.oh. I prefer the 'heritage' of the 7.3 lenses.
I've been buying and recommending harnesses and bulbs (HELLA or Optilux) from www.rallylights.com for years. They build the high quality harnesses from the best parts available. Right here in the USA - and ya get to speak to a real American if you ever need to call.
Vanquish Auto
2017+ Super Duty
18
10-16-2017 02:18 PM
BuckingBull
1999 to 2016 Super Duty
10-12-2014 09:22 PM
pjerrn
09-13-2013 10:55 AM
berick
52
01-14-2010 11:09 AM
riverratmike
29
04-23-2005 02:19 AM
Quick Reply: Stock headlight replacement
