Stock headlight replacement
Old Jan 4, 2016 | 09:52 AM
EcoboostKev's Avatar
EcoboostKev
I posted this in the Superduty section and didn't get a single response. I'm looking to replace my stock headlight assemblies and bulbs on my 2001 F350. Just looking for some advice on what's good and what to stay away from?
Thanks, Kevin
Old Jan 4, 2016 | 10:08 AM
Baatzy's Avatar
Baatzy
Not sure on whats good as I am still running stock with just some regular old headlights, but I am considering going to the 02-04 style headlight and putting in LED bulbs from lifetimeledlights.com. Guys over on the 6.0 forum have been giving good reviews of their lights.
Baatzy
Old Jan 4, 2016 | 11:17 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
This is what I bought, I see they are unavailable now, but I think they were listed on Ebay too.
They installed great, look great and I would get them again. I only wanted a cleaner/fresher look for the truck due to the old ones being hazy looking.
Amazon.com: Ford F-550 Super Duty/ Ford F-250 Super Duty/ Ford F-350 Super Duty/ Ford Exc...: Automotive Amazon.com: Ford F-550 Super Duty/ Ford F-250 Super Duty/ Ford F-350 Super Duty/ Ford Exc...: Automotive
Old Jan 4, 2016 | 02:32 PM
holeshotwalt's Avatar
holeshotwalt
Quick and easy is the 02-04 OEM housings (because the lens stays clear/ doesn't cloud like the older ones).
I had them, but elected to go with OEM 05-07 housings (just 'cause I liked the look). To my surprise, the light output is FANTASTIC compared to the earlier style. The combination of reflector/lens/bulb is really great, and being OEM, they don't leak or fog up.
Old Jan 4, 2016 | 06:22 PM
EcoboostKev
Thank you!
Old Jan 4, 2016 | 06:28 PM
EcoboostKev
Did you use your stock bulbs or Replace those too? Also was there a big difference in visability between the old and new ones??
Thanks
Old Jan 4, 2016 | 06:35 PM
holeshotwalt
By the way, I bought my OEM ones off Craigslist with all bulbs, etc for $60 for the pair. I've also seen them at Pick n Pull.
Old Jan 4, 2016 | 06:47 PM
EcoboostKev
Didn't even think to check craigslist! Thanks.
Old Jan 5, 2016 | 09:16 AM
brian42's Avatar
brian42
Veteran: Navy
Good to hear. I have a set of 05 lights in the garage waiting for me to install them. Did you get an 05 header panel or did you cut yours? A new header panel was not in the budget for the upgrade so I am planning on setting aside at least 1/2 day so I can take my time.
Old Jan 5, 2016 | 10:13 AM
holeshotwalt
I just cut mine- took about 2 hours with a diamond Dremel cutter. If you have bigger saws, it'll go faster. Check the tech stickys for hints and pics...
You'll need an adapter pigtail (or replace the connector) for the different bulbs too. You'll love 'em!
Old Jan 5, 2016 | 07:55 PM
jhl3's Avatar
jhl3
Thanks, Kevin
While you are making your decision, spend $2 on a small can of Deep Woods Off w/ Deet. Spray it on, wipe it off x3....takes about 1 min per light and you'll be amazed at the difference it makes with the old lens.
Old Jan 5, 2016 | 08:11 PM
SkySkiJason's Avatar
SkySkiJason
The best light you can get is from '02-04 lenses with relay harness and 100/80watt bulbs. More usable light than any retro HID and without annoying other drivers.
'05-07 lenses use crappy H13 bulbs and frankly the optics just aren't as good. Besides, it makes the truck look like a 6.oh. I prefer the 'heritage' of the 7.3 lenses.
I've been buying and recommending harnesses and bulbs (HELLA or Optilux) from www.rallylights.com for years. They build the high quality harnesses from the best parts available. Right here in the USA - and ya get to speak to a real American if you ever need to call.
Vanquish Auto
Oct 16, 2017 02:18 PM
BuckingBull
Oct 12, 2014 09:22 PM
pjerrn
Sep 13, 2013 10:55 AM
berick
Jan 14, 2010 11:09 AM
riverratmike
Apr 23, 2005 02:19 AM
