cab redo
Old May 21, 2013 | 11:06 PM
majordad's Avatar
majordad
cab redo
hi i have a 1986 f-150 4x4 wood like to redo whole cab over rugs,redo dash color and what year bench buchet seat's will bolt to old bench.what inusulaion did you use any help will be very thankful jerry
Old May 22, 2013 | 11:47 AM
Franklin2's Avatar
Franklin2
All the cabs are the same up to around 96, a little later for the larger trucks. Anything from old tar paper to the fancy stereo sound blocking stuff will work for insulation.
Old May 22, 2013 | 08:47 PM
ctubutis's Avatar
ctubutis
Some guys here use peel-and-seel from home centers, I think it's in the HVAC section.
Old May 23, 2013 | 08:12 AM
Eddiec1564's Avatar
Eddiec1564
Are you pulling the dash out of the truck?
When I am going to redo my 84 F250's cab, I'll use that spray on rubber under coating and build it up. My friend did his 92 F150 and it quieted the noise down better than I though that stuff would!
On the dash repaint, make sure you use ONE BRAND of paint. I didn't(one brand did not have the proper color) when I repainted the window panels for my 85 Plymouth, the diffrent paints had a fight and now I have munged up panels......
I just repainted my 89 F250 dash, had no problems as I learned from my boo-boo. Just CLEAN the plastic really good and a light scuffing will allow the paint to stick.
Old May 24, 2013 | 07:15 AM
80FlareSide's Avatar
80FlareSide
If you do paint the plastic, consider using TSP to clean it (especially if there is any chance it has ever been Armor-ALL'd) and some sort of adhesion promoter.
JohnFSyd
Sep 4, 2017 02:50 PM
Kenneykole
May 1, 2014 06:35 AM
FordYoungGun35
15
Oct 28, 2013 07:17 PM
frdf250
Mar 28, 2011 07:40 PM
cujo8
Appearance & Dress-Up
Jun 24, 2006 06:37 PM
