I'm not sure where this belongs, so if a Mod disapproves, please relocate it.
I'm looking for a solid, dependable combo set-up (I don't care if they're the same brand either) for a 6.0 F250 bed to fill up tractors and equipment. I need a 'L' shaped liquid transfer tank for farm diesel with the toolbox as well. The transfer tank needs to be electronic pump with the obvious hook-up for pump/filter/nozzle and it needs to be lockable.
I've been looking at Delta, UWS, DeeZee, etc but don't know much about it.
I'd prefer aluminum diamond plate as I'm sure the white painted steel tanks will rust after a couple bumps. If I can put together a franken-combo I wouldn't mind. It's for my company and just need a solid built, non-wallet breaking package here. Where should I look?
Your company may as well get ready to PONY up cause none of that type tank is cheap. Fromm $400 t0 $600 just for the square steel tanks aluminum is more add a couple hundred.
They can be ordered just about any parts supply, Farm supply will have the best price and will often have some instock. I have seen some at Lowes even.
Most steel tanks can last a good while if you keep mud from building up underneeth them.
We always got ours from either Tractor Supply a local company or ordered in bulk from the manufacturers themselves, But then we useually bought a dozen tanks at a time.
And absolutely love it, it has an electric pump that comes with it, all ready to go, all I did was drill three holes bolt in the bed and fill it with fuel
I got a square RDS alum 91 gallon transfer tank for my 2006 It fits perfect in my short box under a toneau cover For $401 and $156 for shipping From https://www.3gtoolboxes.com/index.asp
yup i have a 91 gal rds to. got it at tractor supply, no shipping charge either
