Recommended brake fluid?
Old May 20, 2013 | 12:28 PM
labman1014's Avatar
labman1014
My new front calipers will be here tomorrow and they r going on sat. Well I'm going through a divorce and all my extra fluid is at the house that I don't have access to now and I can't remember what kind it is. What is recommended for my 2000 Ex 4wd v10?
Old May 20, 2013 | 01:59 PM
az_r2d1's Avatar
az_r2d1
I think any DOT3 will do.
I think I used about 1.5 quarts for all 4 corners.
I would flush all 4 while you are at it.
Old May 20, 2013 | 04:57 PM
xbox73's Avatar
xbox73
The OEM Motorcraft DOT3 is actually pretty good, and was, a little surprisingly, less costly at my local dealership than through Amazon. It's pretty cheap.
Old May 21, 2013 | 12:48 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Any DOT 3 or DOT 4 fluid. DOT 4 is in mine because, why not. Its all the same price; cheap.
Old May 21, 2013 | 07:34 PM
tdappleman's Avatar
tdappleman
Any DOT 3 or 4 will work and be 100% compatible with what it in there. If you tow or tend to need heavy braking then a higher quality fluid may be needed. I used to run ATE Super Blue in my race car and now run that in everything. High boiling point and just a good quality fluid. They also make an amber version in case you want a standard looking fluid.
Old May 22, 2013 | 06:00 PM
xbox73's Avatar
xbox73
OEM Motorcraft DOT 3 High Performance brake fluid has a minimum dry boiling point of 500 degrees F, which is close to that of other race fluids like ATE Super Blue.
The OEM Motorcraft DOT 3 does have a wet boiling point that's about 100 degrees F worse than race brake fluid though, and all brake fluid is hygroscopic (readily takes up & retains moisture), so doing a brake fluid flush every couple of years is important to retain brake fluid performance closer to the dry boiling point.
Old May 22, 2013 | 08:08 PM
fmtrvt's Avatar
fmtrvt
As stated, Ford's DOT 3 is a better product then most of the DOT 3s you can buy retail. DOT 4 does have a higher boiling point, but it is more hygroscopic then DOT 3 so unless you change out the fluid every 2-3 years, it won't matter.
tractoman
Aug 24, 2023 08:09 PM
UGA33
Nov 19, 2019 08:40 AM
BigDaddy_2
6.7L Power Stroke Diesel
Feb 11, 2014 01:53 PM
1975Ford
Oil & Lubrication
13
Jan 4, 2007 11:31 AM
jjanssen
1983 - 2012 Ranger & B-Series
21
Sep 17, 2006 01:30 PM
