Sponsored by: Real Truck
Daytime running lights?
Old Oct 6, 2004 | 10:46 AM
02sd's Avatar
02sd
Question Daytime running lights?
I have a 2002 7.3 4x4 crew cab, I would like to get the daytime running lights working, I have installed the daytime running light module/resistor from ford that sits behind the left headlight on the rad cradle and the lights still do not work, is there something else that needs to be installed or am I better of going with an aftermarket setup?
Old Oct 13, 2004 | 02:52 PM
salex's Avatar
salex
For my '04 the resistor was required and a relay box with relays. Remove the cap on the wiring and plug in.
Old Oct 13, 2004 | 04:49 PM
02sd's Avatar
02sd
Is the resistor part #1C3Z-14A601-AA, would you have the part numbers for the relays and where do they go, are they under the hood on the drivers side near the firewall/splashshield where the two small relay boxes with covers on them are?
Old Oct 13, 2004 | 05:04 PM
salex's Avatar
salex
I don't have the part numbers available. Yes to the relay box location. Added relay box uses the same support the existing box uses. Slides right on, on the opposite side of the existing box.
