cowl panel replacement
Old May 18, 2013 | 09:25 PM
zombiefied 247's Avatar
zombiefied 247
I'm getting ready to start taking the old rusty cowl panels off my 55 and noticed that they dont look like they were welded in place they are the original panels... my question is can i get these off without doing to much damage by trying to peel off the panels or should i try to go ahead and cut them off....
Old May 19, 2013 | 07:33 AM
tip49's Avatar
tip49
Spot Weld
Can't speak to the '55 but my '50 was spot welded. Drilled out the welds and welded in new panels.
Tom
Old May 19, 2013 | 08:10 AM
56panelford's Avatar
56panelford
If you clean up the edges you should see where they have been spot welded. You can purchase cutters to drill out the welds. Clean up the surfaces and drill holes on the edges of your new patch panel and plug weld. If you are replacing the complete cowl patch panel it is easier to get to the spot welds at the top seam by cutting the old panel off just below the seam in order to make it easier to drill out the 4 or 5 spot welds
Old May 19, 2013 | 02:12 PM
AXracer's Avatar
AXracer
None of the sheet metal was welded solid, it was all spot welded together.
jm ray
Feb 8, 2013 10:11 AM
Rebel Warrior
Paint & Bodywork
Aug 12, 2008 07:02 AM
slntnddly
Nov 10, 2003 03:25 PM
mudstang2
Paint & Bodywork
Mar 3, 2003 04:15 AM
BenS
May 28, 2000 07:42 PM
