Carburetor Help
Old May 19, 2013 | 01:48 AM
OKC54f100's Avatar
OKC54f100
Carburetor Help
I have a 292 Y-Block in my 54' F100. I am not a very knowledgeable mechanic. I am trying to figure out what I wanna do with the carburetor situation. I have 2 choices. I can find a 4 barrel intake manifold and go to a 500cfm carb or I can keep the 2 barrel and find the best performing carb for that. I was told that someone made a 390cfm 2 barrel carb that performs really well but I am not sure how to find that. I need big time help here and if I can get part numbers that would be great.
Gary
Old May 19, 2013 | 08:52 AM
The Horvaths's Avatar
The Horvaths
Gary, is that 292 running with a loadomatic distributor? If so, that will have a lot to do with your choices.
Old May 19, 2013 | 02:02 PM
AXracer's Avatar
AXracer
Swapping to a 4 BBL manifold and carb will give you no advantage over the 2 BBL on a stock engine, nor will a high performance 2 BBL. Just go with a stock replacement carb.
Old May 19, 2013 | 03:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Getting rid of the Load-A-Crapic would be more bang for the buck, if properly set up.
51FordTN
Nov 19, 2012 11:19 PM
Bwillden24
Dec 20, 2010 10:07 PM
F100racer08
Jun 8, 2008 03:37 PM
mason55
Dec 19, 2005 07:46 AM
63frd
Oct 17, 2004 12:46 AM
