O-ring & return line kit recommendations
Old May 18, 2013 | 05:03 PM
astembridge's Avatar
astembridge
I've been looking for recommendations on what kit to buy for my 84 F-350. I can't seem to find which brand to look for.
What should I look for? What to avoid? A part number would be great.
Old May 18, 2013 | 06:14 PM
Franklin2's Avatar
Franklin2
Is this a diesel I am guessing? If so, you really do not need to buy a kit. Just go to tractor supply or Napa, or someone else that sells O-rings. Buy 16 #111 o-rings(they are 7/16 ID x 5/8 OD). Tractor supply sells them in packs of 8 in the hydraulic fitting section.
Then go to Napa and buy about 5ft of fuel hose. My 89 took 3/16" fuel hose. Some of the earlier trucks like yours may take 1/4". Just make sure it says "fuel" on the side of the hose. You can re-use your caps. Some people have problems with the new caps leaking, I re-used my old caps and have had no problems for 4 years now.
Old May 18, 2013 | 07:00 PM
astembridge
Yeah its a diesel 6.9 liter.
I just ordered a pack of Viton o-rings on Amazon. Was gonna get the viton fuel line but its too $$$. Maybe later.
Old May 18, 2013 | 07:51 PM
Franklin2's Avatar
Franklin2
You only need the viton if you are going to run weird fuels like some biodiesel fuels. I have heard a few people having trouble with the viton o-rings because they can be a little harder than the buna-n and don't seal well. If you are just going to run regular diesel, the buna-n will last a long time, just like the regular fuel hose will.
Old May 18, 2013 | 09:28 PM
astembridge
Well, I will have some spare Vitons I guess. Can Buna-N o-rings be bought local?
Old May 19, 2013 | 07:26 AM
Franklin2's Avatar
Franklin2
That's what the tractor supply and some of the other stores carry. You can try places with good inventories like Napa, and also some places that cater to industrial companies and factories can get o-rings.
You can use the viton, it's just something to keep in mind if you have starting problems after installing them. Make sure to lube the o-rings after they are installed on the injectors, and use a gentle twisting motion when installing the caps over the o-rings.
3000gtman
Nov 20, 2016 07:38 AM
Aussie BrianB
Australia Chapter
Apr 14, 2014 12:32 PM
navistardiesel
Mar 30, 2014 08:13 AM
RA31925
Apr 14, 2011 06:27 PM
whiteaddiction
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 17, 2010 08:37 PM
