Biodiesel-compatible return line kit
Old Apr 14, 2011 | 05:30 PM
RA31925's Avatar
RA31925
I've seen the standard braided hose return line kit (available from Rock Auto, for example) for the 6.9, but I was wondering if one exists that has fluoroelastomer hose rather than rubber. Mine are already weeping and came that way with the truck, and it's only going to get worse running B100.
Old Apr 14, 2011 | 06:07 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Amazon.com: Delphi 7135-264 Injector Installation Kit: Automotive
uses this fuel line:
Goodyear® Engineered Products :: SAE 30R7 DIN 73379-2B Low Pressure Fuel Hose
this ones for the latter 6.9l/7.3's (not your '86.)
Amazon.com: Delphi 7135-276 Injector Installation Kit: Automotive
Doh.
nevermind.it states below this hose isn't good for biodiesel.
well bummer.
i tried.
but you could buy 30R9 separately and use that.
http://www.goodyearep.com/productsdetail.aspx?id=5144
Old Apr 14, 2011 | 06:27 PM
tecgod13's Avatar
tecgod13
Originally Posted by FORDF250HDXLT
Corrected the info on the kits.
After a quick search, it appears SAE 30R9 is a spec for fuel hose that is bio-diesel resistant. Advance Auto supposedly has it for a decent price either in prepackaged chunks, or by the foot. Napa may have it as well, but at a higher cost. Its a "fuel injection" hose, not just regular. Check the writing on the hose, the spec should be listed clearly.
I might check this out, I've pondered making bio, but never had the time. Might have the time this summer, and it wouldn't hurt to get some better line (probably swapping IP pump and injectors next week).
williameub
Apr 8, 2015 09:08 AM
ddeflyer
Feb 19, 2015 12:39 PM
donfordman
Dec 17, 2013 05:19 AM
canister
Mar 27, 2010 12:02 PM
LIGOOMBA
Nov 10, 2008 08:39 PM
