Hi all,
Anyone know where to get hold of Gates Barricade Fuel Injection Hose,
or equivalent in Australia?
I need some to plumb in the Fuel manager filter and auxillary helper
lift pump and cant find any decent hose that is fit for diesel and
rated for pressure.
I ordered a Facet brand lift-pump and a few metres of diesel hose. I replaced the entire run of hose from my tank to the metal line that goes to the fuel bowl - including installing extra filtration & also removing all the quick-connect fittings. I double-clamping all the hose ends.
The quick-connect fittings are notorious for letting air leaking IN.
otherwise your local Aeroflow supplier should be able to sort you out.... mine is Auto Force in Wangara, but that probably isn't much good to you.... he can post though so maybe??
