Shift knob keeps coming off.
Old May 18, 2013 | 04:34 PM
Jarryd's Avatar
Jarryd
Shift **** keeps coming off.
This thing is worn out and if I shift into 2nd hard, the **** comes off and I have to force it back on. Is there any way to make a screw on type shifter fit on these things? I hate this thing, the one thing I don't like about the truck.
Old May 18, 2013 | 04:40 PM
Golden Helmet's Avatar
Golden Helmet
Super Glue?
Old May 18, 2013 | 04:56 PM
Blue Rebel's Avatar
Blue Rebel
^^^^ This ^^^^^
Old May 18, 2013 | 04:57 PM
Jarryd's Avatar
Jarryd
I had considered that, just thought there might be a way to fit something else in.
Old May 18, 2013 | 06:37 PM
Blue Rebel's Avatar
Blue Rebel
Anythings possible. If you can determine the size of the shaft, and what size a screw on handle takes, you can tap it to match, or you could over drill the hole, and weld it on... many options.
Old May 18, 2013 | 07:40 PM
Jarryd's Avatar
Jarryd
I thought about pulling a shifter out of another vehicle that would be better for what I need and modifying it to work.
Old May 18, 2013 | 07:45 PM
garthneddy's Avatar
garthneddy
JB weld FTW
Old May 18, 2013 | 08:25 PM
captain2207's Avatar
captain2207
My buddy made a nice shift know out of white carrera marble.
Old May 18, 2013 | 08:59 PM
Jarryd's Avatar
Jarryd
I was actually thinking about just grabbing a hurst stick out of something and modding the base to work with my shifter.
Old May 18, 2013 | 10:19 PM
joey2fords's Avatar
joey2fords
i had the same problem ... after trying a few mickey mouse solutions i finally went to the wreckers and got the shift **** off an f-series 4x4 of similar vintage . the 4x4 shifters get only a small fraction of the use that the regular shifters do and are usually like new. it fit perfectly and hasn't come off since (use a hammer and a block of wood to drive it onto the shaft).
of course, you will have the 4x4 shift pattern embossed on the ****, rather than the 4 (or 5) speed shift pattern, but we can memorize our shift pattern with a little bit of study, right ?
Old May 19, 2013 | 03:38 AM
GNR22's Avatar
GNR22
RTV Silicone of some sort would keep it on, as would super glue or JB Weld. I have an 8 ball from a local tavern drilled out and JB welded onto my stick.
Old May 27, 2013 | 11:20 PM
1993_f350_2013's Avatar
1993_f350_2013
since my truck is an automatic and 4x4 and purple i polished up an old 4 ball pool ball and im going to drill it out and adhere it to the 4x4 shifter. the only trouble i have with that is how do you drill a pool ball?
Old May 28, 2013 | 12:03 AM
GNR22's Avatar
GNR22
Put it in a vice, but not too tight, as you may split it. Drill it out slowly with whatever size bit you need. Once you get a bite at it, it'll go right through.
Old May 28, 2013 | 12:18 AM
1993_f350_2013
to make it easier could i use a center punch and then a center drill to start it out
Old May 28, 2013 | 01:01 AM
GNR22's Avatar
GNR22
I suppose you could. It isn't a tough material though. They typically have a plastic-like outside and a wooden inside or something similar. They drill out very easily. As long as you don't just throw the drill at it, you won't have any problems with just drilling it out.
