TBC fault
Old May 18, 2013 | 04:33 PM
emmagator's Avatar
emmagator
TBC fault
Truck is displaying a TBC fault, without a trailer. I havent towed in about 6 months. Anyway from researching seems it could be a bad TBC unit or something to do with the brake master cylinder. However, when i get the TBC fault, it appears only for a few seconds and then goes away, i dont have to reset the onboard dash display. Any ideas?
Old May 18, 2013 | 07:57 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Drop the rear 7 & 4 way trailer plugs and see if any of the wires inside are corroded and shorted.
Old May 18, 2013 | 08:51 PM
emmagator's Avatar
emmagator
Yea i checked the plugs, they look real good. No corrosion at all.
Am i interpreting the other TBC fault threads correctly? It sounds like guys who get this fault have the fault code stay on their in dash display until they manual press the reset button, correct? Since my only stays for a few seconds leads me to believe it is some kind of short.
Old May 18, 2013 | 08:55 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
You DID remove the metal shell of the 7-way and look inside, right? If so, you're going to have to check the wiring along the frame rail all the way from back to front for a wear point.....
Old May 18, 2013 | 09:22 PM
emmagator's Avatar
emmagator
If your talking about the wiring harness plug that plugs into the 7way, yes i did.
When a TBC fault trips does it usually stay on dash until manually reset?
Old May 19, 2013 | 06:16 AM
ooms221's Avatar
ooms221
I had a TBC fault come up on my dash and it would be a few seconds after I starred pressing the brakes with nothing in tow. It ended up being that I had no break lights and it was the switch that is under the brake pedal
Old May 22, 2013 | 07:32 PM
emmagator's Avatar
emmagator
Wanted to give and update on this issue. There are two plugs that plug into the bottom of the brake master cylinder. When i was messing around in there changing my ebp sensor i knocked the plug loose, causing my tbc fault. Secured the plug, problem solved. Thanks for the replies.
Old May 23, 2013 | 03:02 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Thanks so much for coming back and letting us know.... We have all done something to screw something up and it is admirable of you to admit fault. And it still does give us all a little more insight into what causes TCB faults!
BPofMD
All Things Towing
23
Sep 29, 2018 04:36 PM
JoshC017
Nov 16, 2016 01:01 PM
mrw1
Jan 1, 2012 06:11 PM
dirtleg
Aug 21, 2011 10:47 AM
WorkhorseF250
Aug 15, 2009 03:53 PM
