Sponsored by: Real Truck
Ford tbc fault
Old Aug 14, 2009 | 02:35 PM
WorkhorseF250's Avatar
WorkhorseF250
Ford tbc fault
got a question, i just bought a trailer brake controler one that is stock for the fords and i plugged it all in and then i get a TBC FAULT on the dash, did i miss something or is something wrong with my truck? i thought it might be a fuse but i would like a idea of where to look.
Old Aug 14, 2009 | 03:56 PM
WorkhorseF250
just wanted to add to this, no there isnt a trailer hooked up and when i unplug the trailer brake controler the fault goes away when i restart the truck. i can reset the dash screen and it goes away juse want to know if its a serious problem, im new to this forum and so far its helped me on a few things so thanks for your info
Old Aug 14, 2009 | 04:21 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If the truck did not come with the TCB system installed, you will also have to add the Master Cylinder that works with the TBC then have the computer reflashed for the TCB to work correctly.
Old Aug 14, 2009 | 05:21 PM
WorkhorseF250
well the truck didnt come with the trailer brake controler in the cab but the rest of the trailer equipment is there i think? what do i look for on the truck to know if it has the MC and how would i know its been reflashed, i bought the truck with 120kms and its been great so far it has all the connectors on the back tho
Old Aug 15, 2009 | 10:06 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
If the truck did not come with the TBC, you do NOT have the correct Master Cylinder.
Old Aug 15, 2009 | 03:53 PM
57fomoco's Avatar
57fomoco
You are correct we have installed several on our fleet that came without the controller and you must change the m/cyll. we finally got our fleet manager to check the box for TBC when he orders trucks because it is alot cheaper to add it on the build sheet.
Rotterdam24
Oct 20, 2016 07:23 PM
Acekris13
6.4L Power Stroke Diesel
Jun 14, 2016 04:56 AM
Shawnsmalibu
All Things Towing
Aug 4, 2015 11:28 AM
Vinford
Jul 5, 2015 12:43 PM
tcorbitt
May 27, 2007 09:03 PM
