Electrical issue with Park lights
Old May 18, 2013 | 01:39 PM
68 351 bronc's Avatar
68 351 bronc
I'm posting on the 7.3L forum but I have a 2001 V10 F250. I'm hoping I'll get help here.
My Park lights won't shut off. Even with the head light switch disconnected.
I pulled fuse # 8 under the hood which is labeled for the park lights. The lights stayed on.
Next I located what I believe are park light relays 1&2 next to the fuse box under the hood. Pulled both these relays and the lights stayed on.
There are also 2 relays in the small box with the emergency flasher relay. This is located in the center of the instrument panel approximately behind the radio. I pulled these and the lights stayed on.
There are also 2 relays behind the glove box in front of the heater box. I pulled these and the lights stayed on.
Ford manual says the two relays in the center dash should be trailer tow relays. The two in the right hand side of dash behind glove box should be park light relays but they don't resemble the park light relays in the service manual. The two relays under the hood next to the fuse box resemble the park light relays in the service manual.
I need some help. How do I get the light shut the hell off?
jhcorley
Aug 25, 2020 06:49 AM
majemi05
May 20, 2019 04:41 PM
Bjbeard
Jul 16, 2018 05:10 PM
scar98
1997 - 2003 F150
Nov 6, 2004 05:44 PM
boosterca2001
Aerostar
Aug 1, 2003 02:09 PM
