Vacuum pump/booster problems
Old May 17, 2013 | 06:05 PM
96ford250's Avatar
96ford250
My truck is running and moving and all is well but now it's hard to stop. My donor truck was a roll over and the original brake booster was full of some kind of oil I'm guessing from the pump so I left the gas booster on there to see If i could get away with not replacing it well I'm pretty sure that was a bad idea. Will the oil in the original diesel brake booster hurt anything or should it be replaced? My other question is what kind of vacuum does these pumps pull I put my finger over the port and I feel like I'm barely getting anything at idle is that normal or am I looking and a pump and a booster? Any help would be greatly appreciated thanks.
Old May 19, 2013 | 01:09 PM
rodneywar's Avatar
rodneywar
gas and diesel boosters are the same boosters. your vac pump is going out replace the pump first before you replace the booster i am leaning towards just a pump
Old May 19, 2013 | 07:37 PM
farmert's Avatar
farmert
I'm with Ronnie. The vaccume pump should pull a minimum of 17 in. if I remember right.
Old May 19, 2013 | 07:43 PM
96ford250's Avatar
96ford250
Ok thanks like I said I could barely feel anything from the port at idle but I didn't know if it had to have more rpm to pull more vacuum
Jay_Sliver
37
Apr 23, 2012 08:35 AM
gumper 123
22
Mar 6, 2011 11:34 AM
Dieselthree
Feb 7, 2010 02:36 PM
gov2mod
Oct 27, 2004 01:54 PM
MSC
13
Jul 10, 2004 06:31 PM
