Vacuum Pump info needed..
Old Feb 11, 2012 | 08:53 PM
Jay_Sliver's Avatar
Jay_Sliver
Hi guys/girls
Newer to the forum, joined the board to gather info on my inlaws 1998 Ford E350 Cubevan with a 7.3 diesel.
Problem is in relation to the brakes. The pedal is rock hard (as if it has no assist) unless you slip the trans into neutral and hold the rpm's up around 1200. As an ex toyota/lexus mechanic, I diagnosed it as a bad brake booster, as it showed most of the signs/symptoms of a failing brake booster. Today, I replaced the booster, and the problem still exists.
With the engine running, I can pull the vacuum line off the booster, and there is vacuum there, but noticeably less than that of what a gas engine would provide. I'm looking for a vacuum spec I guess. What kind of vacuum should the vacuum pump pull at idle or slightly above idle?
My new thought is that the vacuum pump is not pulling enough vacuum.
Jay
Old Feb 11, 2012 | 09:03 PM
farmert's Avatar
farmert
You are right on the vac pump. The vac pump should pull at least 17 in. A quick check if the vac pump is bad is the heater defaulting to defrost, no matter where the dial is set.
Old Feb 11, 2012 | 09:04 PM
BlueMule's Avatar
BlueMule
IIRC the manual calls for something like 18-20 in.
Old Feb 11, 2012 | 09:08 PM
bad12jr's Avatar
bad12jr
Could also have a belt slipping. Something to look at and a little easier to change.
Old Feb 11, 2012 | 09:20 PM
Jay_Sliver's Avatar
Jay_Sliver
10-4. I did check the mixer door function when I had it running today, and it did seem a little lame, or slow to function. I checked the vac lines from the vac manifold to the vac ball at the drivers headlight and it appears to be in good shape, not cracked or broken. The line to the booster is in good shape, and the check valve functions as it should.
When I test the vacuum pump, is it ok to test it up at the vacuum manifold, bu pulling a line off for say, the vacuum ball?
Thanks for all your speedy input.
Jay
Old Feb 12, 2012 | 07:36 PM
farmert's Avatar
farmert
I usually check the line at the brake booster, but any where you can hook up the guage will work.
Old Feb 13, 2012 | 06:29 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
17-21 in-Hg is what my book shows = 57-70 kPa
At idle below 10in for more than 7 seconds will illuminate the brake lamp.
Most vac leaks i have found have been at the heat/ac control.
BTW if you sit pumping the breaks you can deplete the vac and set the lamp.
Old Feb 13, 2012 | 06:35 PM
Jay_Sliver's Avatar
Jay_Sliver
That's the problem though, the pedal is rock hard. Its like trying to put your foot through a brick wall. I cant pump the brakes enough to deplete the vacuum and cause the light to illuminate.
I have not yet had a chance to get over to their warehouse and test the vacuum. Thank you for the actual spec.
Jay
Old Feb 13, 2012 | 06:59 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Jay
You are welcome. BTW how much was the brake booster?
Old Feb 13, 2012 | 07:04 PM
Jay_Sliver's Avatar
Jay_Sliver
$75 Canadian from a local wreckers. Took them 3 times to pull the right one, but they got it. First one had an 1 5/8" hole for the master cylinder, where I required a 2" hole. The 2nd booster they sent me was a hydro-boost unit....I told them exactly what I required, hole size and all, and they send me a hydro-boost unit.. 3rd and final unit was the correct 2" hole Vacuum assisted brake booster.
Jay
Old Feb 13, 2012 | 07:14 PM
BlueMule's Avatar
BlueMule
That's the way mine was too. I had the hard pedal and the light never came on. And the heater controls worked the way they were supposed to. I thought it was the brake booster but I didn't want to make two trips to the parts store so I bought the booster and pump and rented/borrowed a pulley puller and vacuum gauge. The pump was only pulling 10 inches of vacuum so I replaced it and returned the booster.
Old Feb 13, 2012 | 07:58 PM
Jay_Sliver's Avatar
Jay_Sliver
Good to know. Thanks for the info.
Jay
Old Feb 13, 2012 | 08:15 PM
Action4478's Avatar
Action4478
How many reasons can you think of to have the belt slip ?...
Old Feb 13, 2012 | 08:51 PM
BlueMule's Avatar
BlueMule
eight.....
Old Feb 14, 2012 | 08:18 AM
Action4478's Avatar
Action4478
eight.....
On one pulley ?...
