Original CPS found
Old May 19, 2013 | 05:46 PM
  #31
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I took an OEM Black, a working Borg Warner (which I previously said was black, but I stand corrected. The stock image online is black, the physical CPS is grey.) and an OEM Grey.
I took a line of 1/4 oz wheel weights and attempted to suspend them from the each cps, then took off one weight at a time until the CPS magnet could fully lift the string of weights. I found that the OEM black could support MUCH more than the OEM grey and the BW fell in the middle.
Also, to verify what was said above, the OEM Black and BW CPS both have large ends, where the OEM grey has a smaller end.
Old May 19, 2013 | 06:04 PM
  #32
Snowseeker's Avatar
Snowseeker
PM'ed back a couple PM's.
Old May 19, 2013 | 06:09 PM
  #33
Pitcrw6's Avatar
Pitcrw6
Trey, have u tried the new one Clay sells now?
Old May 19, 2013 | 06:10 PM
  #34
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Youre referring to the "improved" CPS from International? No I havnt. If someone wants to send me one I would be happy to
EDIT: I just looked and cant find it on his website, but you can buy it other places. I dont believe this new CPS has a Ford part number because it is from International and after the time that Ford would be adding parts to the 7.3 parts bin. The IH part number is 1876736C91.
Old May 19, 2013 | 06:13 PM
  #35
Pitcrw6's Avatar
Pitcrw6
Yes that's the one im referring too
Old May 19, 2013 | 06:26 PM
  #36
Snowseeker's Avatar
Snowseeker
I also wonder what 'other' CPS's would work on the 7.3 since they are ALL basically the same even from other makes.
Along the same lines I wonder what 'voltage' feedback the computer likes best to work with.
Old May 19, 2013 | 06:53 PM
  #37
Snowseeker's Avatar
Snowseeker
Lots of good reading here: CPS Testing Information - Diesel Forum - TheDieselStop.com
Old May 19, 2013 | 09:30 PM
  #38
A/Ox4's Avatar
A/Ox4
9 ECHO 1
After the little test today, I put the black one back in my truck. I had removed it when my IPR took a dump as a first step of eliminating it. Well its back in now and man, it idles so nice again!
Old May 19, 2013 | 09:44 PM
  #39
Stewart_H's Avatar
Stewart_H
Originally Posted by A/Ox4
So my understanding from that is the BW CPS is potentially very good, just more sensitive to interference, so if you isolate the ground, you now have a good CPS?
I was looking at it the whole time, but I was too tired to see it in TARM's post because it wasn't the very first paragraph.
Here's his post at PSA:
Originally Posted by TARM
* Borg Warner CPS CSS1603 ( this is a duplicate of the old Black original CPS. Its grey but its full sized and has the same hall sensor specs, centered and right at the surface tip (you can see it thru the plastic) Test your intermittent wipers. If it causes engine surge or cuts out the Wiper motor is going bad and throwing interference thru the ground wire. It shared a common ground with the CPS and PCM (Can you say stupid) Cut the wiper ground where it joins and ground it by itself somewhere else. This will solve the issue. Advanced Auto with online coupon TRT30 and choose in store pickup $18. Huge dif in idle compared to Ford Grey)
Stewart
Old May 20, 2013 | 10:25 AM
  #40
Studawg's Avatar
Studawg
Thread Ender
A Ford dealer did the recall on my truck before I knew anything about this. I assume I have the Ford gray. So yall are saying that if I get this new CPS it will smooth my idle? Ive got a spare in the glove box, but I dont even know what kind it is. Ive never had a problem with any CPS, knock on wood.
Old May 24, 2013 | 07:46 AM
  #41
Crewcab Turbo's Avatar
Crewcab Turbo
I just got the CSS1603 to try. Where exactly is this ground I should separate?
Old May 24, 2013 | 04:58 PM
  #42
90pioneer's Avatar
90pioneer
I've tried the grey, dark blue, borg warner css1603, and currently have an original black cps installed.
My truck exhibits 0 difference between the four. Still have an idle problem.
Old May 24, 2013 | 05:06 PM
  #43
hydro man 17's Avatar
hydro man 17
Just installed the BW CPS and a big difference in idle, much smoother than with the Ford recall unit. Still need to do the hutch/harpoon mods but way smoother just the same. Almost reminds me of the 283 at trolling speed in an old Chriscraft I used to have.
Also tested the wipers and no issues so far but only ran them a few cycles full on and intermittent.
Old May 24, 2013 | 07:47 PM
  #44
SpringerPop's Avatar
SpringerPop
Keeping your grounds clean and shiny will go a long ways toward reducing idle or wiper-interference problems. It's something you should do every few years, anyway.
Brighten the sheet metal, as well as the wire lugs, with a wire brush or somesuch. Make them bright and shiny! Then use some NoAlOx anti-oxidizing paste on them to keep off the water and air.
There's a couple on the other side of the truck, too, but they don't seem to make as big a difference.
Pop
Old May 24, 2013 | 08:07 PM
  #45
Stewart_H's Avatar
Stewart_H
Like Marv stated, Noalox is good stuff!
Stewart
RÖENTGEEP
21
Dec 9, 2014 12:17 PM
Dutch Semi
Apr 16, 2012 05:35 PM
Bigcat350
21
Jan 7, 2010 04:49 PM
7.3mule
Feb 18, 2009 01:47 PM
willbd
Dec 24, 2005 11:10 AM
