6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Upfitter switches
Old May 17, 2013 | 01:25 AM
dieselsmoker's Avatar
dieselsmoker
Upfitter switches
im installing a 20 inch rigid light bar to my truck and was wondering what switch is best to run the light bar off. I know that aux 1 and 2 are 30 amp, aux 3 is a 10 amp and aux 4 is a 15 amp. im just not sure what one I should hook the bar up to. I don't want to over or under power the light bar. also I need to hook up 3 1/2 inch lights that came with my smittybilt bumper and they are 55 watt 12 volt lights. what upfitter switch should I hook those lights up to. any insight would be great thanks
Old May 17, 2013 | 04:29 AM
fordtruggy's Avatar
fordtruggy
All 4 switches are 12 volt so you won't over power any of them. Ide use the lesser amp switch for the LEDs and the 15 should run the other 3 lamps just fine.
Old May 17, 2013 | 05:18 AM
senix's Avatar
senix
I was gonna say...what is the rating of each of the lights but I think Fordtruggy has you pointed in the right direction.
Old May 17, 2013 | 08:16 AM
dieselsmoker
so pretty much use the 10 amp aux switch to power the light bar then. im not gonna have trouble blowing fuses if I use it.
Old May 17, 2013 | 11:27 PM
jlrFordFan's Avatar
jlrFordFan
Electrical formulas
What is the power rating on the light bar?
Here are a couple of real easy formulas you can use to find out about about your loads...
Eq. #1) P=I^2*R
Eq. #2) V=I*R
Where P is power (watts); I is current (amps); V is potential (volts); R is resistance (Ohms). Since in accessories we rarely talk about resistance, we solve Eq. #2 for R --> R=V/I and then substitute this new version of Eq. #2 for R in Eq. #1 which gives us P=I^2*V/I or simplified P=I*V. So when you know power (55watts) and voltage (12volts) as in the case with your lights, and you want to know how much current they'll draw, you just solve our new version of Eq.#1 for I, it looks like this I=P/V, then simply plug in real numbers and viola or in other words "whaaalaaa"
I = 55/12 --> I=4.6 amps
For your light bar replace the 55watts in the equation with whatever the light bar's power rating is and calculate.
USArmyRET_RKSmith
Aug 30, 2018 09:13 AM
Andrew.Legault
Electrical Systems/Wiring
Apr 1, 2013 04:42 PM
SCRWDRVR
Delaware Chapter
17
Apr 2, 2008 10:49 PM
ABFord
Oct 20, 2007 07:01 PM
Douglas DC-9
Jun 13, 2005 09:17 PM
