6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Stalling at stops
Old May 16, 2013 | 10:50 PM
brycemc's Avatar
brycemc
Stalling at stops
Ok gents I'm working on a customers 08 f450 he says it occasionally stalls when he's coming to a stop I've got a particulate filter pressure sensor code so I record the freeze frame on it and clear the code. i drove the truck home tonight, (25 mile trip one way) it runs great for the first 18 miles all freeway then I get to the off ramp and it dies. No bucking surging nothing, like someone turned the key off, No codes yet 10 minutes it fired up again, next stop dies again. I look at the data stream and see fuel rail pressure at ~80 psi then I crank it and hits ~500 psi, no start. Let it sit, crank it fuel pressure hits 2200 psi and fires up then idles around 6000psi. As I'm pulling into the house it dies again. Same fuel pressure readings ~500 cranking and the filter pressure sensor code is back. Any ideas would be appreciated thanks
Posted in 2 sections. Didn't realize there is a 6.4 specific section. Didn't mean to break any rules
Bryce
Old May 17, 2013 | 05:17 AM
senix's Avatar
senix
Fuel rail pressure sensor...or maybe the VCV. You had a p2002?
Old May 17, 2013 | 07:49 AM
brycemc's Avatar
brycemc
It was a p2452 I believe. Particulate filter pressure sensor
Old May 17, 2013 | 07:59 AM
senix's Avatar
senix
P2452 Diesel Particulate Filter Pressure Sensor "A" Circuit D* DPFP-A
Sensor is the in front of the DPF...not to be confused with the EGT sensor I beleive. Don't have my manual in front of me.
Old May 17, 2013 | 04:36 PM
brycemc's Avatar
brycemc
Just an empty case. No filter. Would this shut the truck down like that?
brycemc
13
May 19, 2013 09:49 PM
nitro3421
15
Aug 20, 2012 05:29 PM
JT Smitty
19
Aug 16, 2012 03:39 AM
sawtooth
Dec 12, 2010 07:15 AM
extrat162
Nov 23, 2010 09:40 PM
