loosing power
Old Aug 15, 2012 | 07:43 PM
JT Smitty's Avatar
JT Smitty
loosing power
I have a 99 f350with 7.3. I loose power after 10 miles or so and if i let it sit for a while it will be fine for a bit and then act up again. I have changed fuel pump, fuel filter, air filter, cam shaft sensor, high pressure oil sensor, and back pressure sensor and cleaned the tube. I put it on the modis and it says low back pressure sensor and cam shaft sensor still after I cleared the codes twice. It acts like its running out of gas. Can some one please help me?
Old Aug 15, 2012 | 07:47 PM
BigAlsPSD's Avatar
BigAlsPSD
Check fuel pressure, maybe consider the "Hutch" mod to eliminate the mixing screens.
Do you know which code number it was for the EBPS?
Old Aug 15, 2012 | 07:54 PM
JT Smitty's Avatar
JT Smitty
there is no code on it now the only code that came up was ICP pressure above/below desired code #P1211
Old Aug 15, 2012 | 07:55 PM
JT Smitty's Avatar
JT Smitty
i don't loose fuel pressure when it acts up
Old Aug 15, 2012 | 08:18 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Check for boost leaks!!!
Old Aug 15, 2012 | 08:20 PM
CSIPSD's Avatar
CSIPSD
How do you know you dont loose fuel pressure?
Old Aug 15, 2012 | 08:22 PM
JT Smitty's Avatar
JT Smitty
i have the modis still hooked up to my truck when it acts up and i can see the readings.
what ami looking for with boost leaks?
Old Aug 15, 2012 | 08:27 PM
BigAlsPSD's Avatar
BigAlsPSD
The PCM can not view fuel pressure. There is no PID for it. You can view ICP(Injector Control Pressure) but that is the high pressure oil side of the injector.
Old Aug 15, 2012 | 08:30 PM
JT Smitty's Avatar
JT Smitty
would't the icp drop if the fuel pressure drops?
Old Aug 15, 2012 | 08:32 PM
BigAlsPSD's Avatar
BigAlsPSD
Sometimes you can get an uncontrollable 1211 due to low fuel pressure. But PCM is still going to try to command desired ICP and may achieve.
Old Aug 15, 2012 | 08:34 PM
JT Smitty's Avatar
JT Smitty
so where would i look for low fuel pressure. I have changed the pump and the filter and i had the tank out and the screen is fine
Old Aug 15, 2012 | 08:40 PM
BigAlsPSD's Avatar
BigAlsPSD
Fuel pressure test ports on the filter bowl.
http://www.guzzle7pt3.com/pics/fbowl/newFuelBowl.jpg
Old Aug 15, 2012 | 08:41 PM
JT Smitty's Avatar
JT Smitty
where would the problem be if it is low
Old Aug 15, 2012 | 08:42 PM
BigAlsPSD's Avatar
BigAlsPSD
What is the oil level and condition?
Have you been monitoring live data when it dies?
Old Aug 15, 2012 | 08:43 PM
JT Smitty's Avatar
JT Smitty
oil is fine and yes i have been
