coolant randomly going somewhere
Old May 17, 2013 | 12:47 PM
blue924.9's Avatar
blue924.9
when you have the hood popped and looking at the motor it is on the bottom right corner
Old May 20, 2013 | 01:39 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
The leak wouldn't have to be in the core to let air into it, check the lines coming out into the engine bay. One is usually routed to the throttle body, which could be your leak itself. A leak in the throttlebody area could introduce air, as well as make coolant vanish as it ingests it into the engine while it's running.
I'm not positive you are set up that way, but it's a possibility.
Old May 20, 2013 | 02:00 PM
blue924.9's Avatar
blue924.9
well i found out that my mechanic drained some and started it, than added some and that it most likely went down as the air got burped out of the system. we will see if that holds up in the future but for now i am very relieved
Old May 21, 2013 | 07:01 AM
austinlittle34's Avatar
austinlittle34
Question
Originally Posted by blue924.9
as a note the water pump is a bit wet, but not wet enough to be the source as this is a fairly big leak. also i didnt get the chance to pull the cover off of the heater core, but i do know the system has to be under pressure for it to leak.
You need to go and get a radiator pressure tester you can rent one from your parts store and if you still don't find it when you change your oil drain some into a mason jar and let it sit over night and it will separate if there's water or coolant in there
Kamo95
39
Oct 4, 2019 06:39 PM
mytoolman
51
Jul 7, 2019 11:22 AM
ars_lurker
1997 - 2003 F150
Sep 8, 2007 05:44 PM
jonnybronco
Jan 9, 2005 08:44 PM
blackpowder
Apr 3, 2003 06:49 PM
