Thanks for the info. The PCM seems like the logical possibility, and is run by a lot of sensors and feedback, so I will work on the error codes and eliminate any electronic malfunction, then have the PCM looked at. I think the PCM is not cheap!!!
...Still looking for the injection pump!!!:0
... Just joking!! After you explained it was Fuel injection pump, It was clear that there was no FIPL!!!)..Appreciate the help!!
The trans command CANNOT reduce downshifting. The downshifting decision is made in the PCM, not in the transmission. All the trans command can do is affect how soft or harsh the shift is. It cannot change when the transmission shifts.
Mark, I did a little search on the Banks TransCommand module and here is the detailed explanation of what you already stated.
