Sponsored by: Real Truck
Ball joints/steering question
Old May 22, 2013 | 01:46 PM
Andyman50's Avatar
Andyman50
Searched but couldn't find an answer.
99 F250 super duty 7.3
Had new ball joints installed and alignment. Steering does not return to center. Returns a little on a tight turn like intown but difficult when just changing lanes in town or not. Took it to another shop and they said the ball joints were too tight. right side pretty tight and left side really tight. Moog ball joints. First mechanic says they will getter better with a few miles on them. Second mechanic says not so.
also, have new shocks but get a bouncing in the front when at 45 mph and goes away at almost 50 mph. Any thoughts? Already have about $700 in this job.
thanks!
Old May 22, 2013 | 05:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
What are the specs on the alignment?
Old May 22, 2013 | 09:08 PM
CuNmUdF250's Avatar
CuNmUdF250
sure someone will correct me if I`m wrong but I think the tops get torqued after bottom ones and if not it`ll give you the problem you`re describing...but also I thought on the alignment that they loosen the top ball joint then retorque so you would think that would fix your problem provided it was a legit alignment ....I`ve also heard they can be a lil stiff at first to
Old May 22, 2013 | 09:20 PM
redford's Avatar
redford
I just had new ball joints installed a few weeks ago, and the truck was aligned. Moog joints were used. I am not experiencing any issues. Don't let them tell you that what you are experiencing is normal.
Old May 22, 2013 | 09:28 PM
JWC 3's Avatar
JWC 3
If the ball joints are installed improperly the seat and housing can be deformed . That will cause memory steer , lack of return . The proper tools need to be used to avoid this issue . Some brands are more prone to this type of issue than others .
Old May 23, 2013 | 09:30 AM
Buck268's Avatar
Buck268
Are the BJ's greased? What is your caster set at?
Old May 23, 2013 | 11:04 AM
Andyman50's Avatar
Andyman50
After putting on a few miles the steering seems to be getting back to normal. I still have the bounce at 45 mph that goes away at about 48-50 mph. Not sure what the alignment specs are. Les Schwabb did the alighnment. And don't know what the caster is set at but it is steering much better. Don't know what else to say...
Old May 23, 2013 | 11:11 AM
droldsmorland's Avatar
droldsmorland
Ha JWC3 just caught your signature quote...Nothin runs like a two stroke Detroit! And the only time it aint leakin is when its off! We install slobber boxes on the larger indoor units, the 12V71 & 92s & 16V149s but that sure dont stop all of it! Worst thing they ever did was go 4 stroke!
Old May 23, 2013 | 03:50 PM
bashby's Avatar
bashby
Your vibration is probably a tire out of balance.
Old May 23, 2013 | 04:37 PM
Andyman50's Avatar
Andyman50
Maybe. Buy I had all four tires balanced on Friday the bounce thing was there on Saturday. Maybe need to get them rebalanced.
Deagle12
Nov 14, 2017 12:29 PM
bma2001
Feb 19, 2015 05:14 PM
Ryan50hrl
2004 - 2008 F150
May 17, 2009 10:14 AM
kengarchow
Mar 31, 2008 06:02 PM
jeeptroll
May 8, 2007 09:20 PM
