64 F100 Radiator
First and foremost, welcome to FTE!!!
Topic comes up on occasion. Ran a search and found a thread where author mentions LMC as a source but suspect many of the Ford pickup part suppliers purchased the support from the same source. Noticed Dennis Carpenter also offers the 61-64 support for bout same cost. Suggest check with a Ford part supplier closest to your location to save some of the cost for shipping. Learn from experience, call to confirm items is in stock; in addition, never discard the old part until the project is completed, number of times found the replacement did not contain all the fasteners, etc, and I had to use components from each before reassembling; also may need the original as a templet. Posting a link to a thread by bluestang65 where he modified a 64 for his 66 may find helpful??? Suspect other member's will be chime in with comments and suggestions??
https://www.ford-trucks.com/forums/1...or-66-use.html
Topic comes up on occasion. Ran a search and found a thread where author mentions LMC as a source but suspect many of the Ford pickup part suppliers purchased the support from the same source. Noticed Dennis Carpenter also offers the 61-64 support for bout same cost. Suggest check with a Ford part supplier closest to your location to save some of the cost for shipping. Learn from experience, call to confirm items is in stock; in addition, never discard the old part until the project is completed, number of times found the replacement did not contain all the fasteners, etc, and I had to use components from each before reassembling; also may need the original as a templet. Posting a link to a thread by bluestang65 where he modified a 64 for his 66 may find helpful??? Suspect other member's will be chime in with comments and suggestions?? https://www.ford-trucks.com/forums/1...or-66-use.html
Originally Posted by mike macd
I just bought a 1964 F100 with a 351W and I need a radiator.
1961/64 F100/250 & F350 with single rear wheels uses the same radiator.
Here's the radiator support info: C2TZ-16138-G / Reproduced
1961/64 F100/600 / 1965 F100/250 4WD / 1965/66 F350/600 / 1966 F250 4WD
jcrabb13
15
Aug 6, 2015 03:45 PM
ofchump
16
Feb 15, 2008 09:08 PM
jamesyoung
Jan 28, 2005 07:16 AM
