1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2003 Exp side power mirrors not operating
Old 05-15-2013, 07:12 PM
stevebigos's Avatar
stevebigos
stevebigos is offline
2003 Expedition EB, 4 wd, EB, 5.4l.
Both power side mirrors do not function from the door switch. The only time I have seen them move at all is when I hit the Mem button on the door, and that only moves the left mirror very slightly.
I made just a real quick check at the door panel mirror switch and found power to one terminal. I know how to remove the mirror glass and the door panels, nothing obvious there like loose connections. No bad fuses. Is there a relay?
I'm looking for troubleshooting tips and theory of operation, like what the heck does the DSM have to do with the mirror operation. Wiring of the door switch would be really helpful, then I could at least jumper at that connector and see what happens.
Also interested to hear if anyone has successfully bypassed the reverse mirror tilt function, since it seems like that function causes a lot of issues.
Thanks for any advice.
Old 05-15-2013, 08:37 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
Cant help with the switch issue, but on an 03 you can turn off the mirror tilt function in the message center.
Old 05-16-2013, 12:12 AM
alloro's Avatar
alloro
alloro is online now
Received 4,253 Likes on 2,479 Posts
Since the memory button will give movement you can assume the mirror motors are good. This leaves you with the high probability of a bad switch.
Old 06-22-2013, 05:41 AM
stevebigos's Avatar
stevebigos
This did turn out to be the switch. Found a good buy on a NOS part and it works fine now. Thanks.
StrangeBrew69
6.4L Power Stroke Diesel
06-14-2018 09:53 AM
boulderbronco
1999 to 2016 Super Duty
15
01-28-2012 12:17 AM
LCAM-01XA
05-05-2010 11:16 PM
Club Wagon
1997 - 2003 F150
10-20-2007 05:53 PM
99350psd
01-17-2005 12:29 PM
Quick Reply: 2003 Exp side power mirrors not operating
