Temp. Probe location
Old May 14, 2013 | 10:30 PM
Raleigh1's Avatar
Raleigh1
So I finally got around to installing my ECT sensor this weekend.
I am seeing temps on the guage up to about 235-240 when loaded (about 13,000 # on a decent grade at about 40 MPH) after all of the work has been done.
I have replaced the t-stat with the Ford variant
I have installed a new fan clutch, seems to be working, I can hear it somewhat.
Coolant system flushed and back flushed with cascade detergent, got some crud out, but I can see some corrosion in the top of the radiator when it is empty.
After all this work was done (today) I pulled the same grade and it was about 20* cooler than before but still seems warm to me.
My sensor is mounted in the lug on the top of the water pump, does this spot have hotter coolant than in the heads? The stock gauge reads low, I know they are crappy.
My concern is that I am towing tomorrow morning from Salt Lake to Vegas my Bronco, total weight is about 13,000 #.
Any thoughts? I am leaving early at 4:00 AM to beat as much heat as possible and I guess just take it easy, it seems to do just fine on flat or small grade, but once it get warm it takes a long time to cool down.
Old May 15, 2013 | 12:15 AM
Fordidipower's Avatar
Fordidipower
That is a little high to me. I think standard temp is 205 to 215. Yes take it easy but don't lug the motor. Do you have a exhaust gas temp gauge? You need one towing that much wieght. Personally I wouldn't get the motor to much above 220. I know that 260 is death to a motor. Hope that helps
Old May 15, 2013 | 02:38 PM
Raleigh1's Avatar
Raleigh1
She did great!
The highest I saw was 225 on a long grade. I drove by the temp and backed off when it got too high which wasn't as much as I had expected.
I do have an EGT and it never got over 1100. I tried to keep it under 1000, that worked well.
I averaged 12.3 MPG!
Old May 16, 2013 | 01:22 AM
Fordidipower
Hey that's awesome man. Glad there was no probs for you
bcaughhorn
Jul 2, 2015 06:35 PM
olfordsnstone
Aug 3, 2014 12:35 PM
RideDiesel88
Sep 27, 2012 04:57 PM
nbaker
Feb 14, 2010 07:09 PM
Benchwrench
Aug 28, 2008 04:20 PM
