What V10 mods to do while the engine is out?
Old May 14, 2013 | 12:13 AM
BigRedSD's Avatar
BigRedSD
My engine is toast (sounds like it spun a bearing). The engine is on it's way out of the truck while I source a replacement. Since I will be paying the labor to remove it, what (if any) mods should I consider? I wouldn't mind getting a few more ponies under the hood for the right price!
Old May 14, 2013 | 01:07 AM
Apocalypse's Avatar
Apocalypse
Could always balance it perfectly, a perfectly balanced motor is a beautiful thing
Old May 14, 2013 | 05:29 AM
sammie0126's Avatar
sammie0126
If my engine was out I would replace the body mounts on the front end, they get old and creak and to replace them you have to lift the body or the engine some to get the clearance. I would also address any rust issue you have on the supports around the engine.
Old May 14, 2013 | 08:00 AM
jh818's Avatar
jh818
I would replace the exhaust manifold/studs.
Old May 14, 2013 | 08:14 AM
sammie0126's Avatar
sammie0126
Definitely +1 on that one too
Old May 14, 2013 | 09:04 AM
ComputerCowboy's Avatar
ComputerCowboy
put a blower on it, get some sort of crazy cam
Old May 14, 2013 | 09:11 AM
cw_mi's Avatar
cw_mi
Replace it with an inline 6... a Cummins
Just go thru all the known issues with the motor. Exhaust manifold bolts, if you go headers you don't have to worry about them again. Maybe replace the IAC valve (not sure if that is the right name) , the thing that helps this motor idle. Water pump.
Replace the flexplate and upgrade the torque converter if you plan on towing. New Y pipe..
Is there any preventative for the spark plug threads ? Just to make sure no plugs come flying out.. one less thing to worry about.
As far as HP, more is nice but anytime you start adding this and adding that it usually opens up a can of worms.
Old May 14, 2013 | 10:19 AM
EXv10's Avatar
EXv10
Ford already did it all except where they screwed up on the studs.
Shorty Thompson
Mar 30, 2019 06:56 PM
MrCooper
Aug 25, 2018 05:42 AM
PROSTOCK
Jan 25, 2016 02:33 PM
UrbanXX
Sep 5, 2011 01:42 AM
mrroofer
Nov 2, 2003 02:39 PM
