Under seat sub
Old May 15, 2013 | 07:36 AM
Excursion123's Avatar
Excursion123
Under seat sub
Hello, yesterday I installed 4 coaxial pioneer speakers and a single din pioneer head unit. The speakers sound awesome but do lack some deep bass. I would like to add a sub but I don't want a huge one just thrown into the back of my excursion.
I was looking at these shallow mount subs for under the 2nd row seat of the ex:
TS-SW3001S2|S4 - 12" Shallow Mount Subwoofer with 1500 Watts Max. Power | Pioneer Electronics USA
Do they sell pre built boxes that fit under the second row seat of an excursion? I would like to have 2 of these subs under the second row seat.
Thanks Alot for the help.
Old May 15, 2013 | 08:13 AM
bcrewcaptain's Avatar
bcrewcaptain
I'm not aware of any that will work well under the seat. The issue you're going to be looking at is minimal space. They sell underseat boxes for some vehicles, but being as the X seats tumble and slide as well, there isn't enough space for anything under there. Between the speaker itself and the material for the enclosure, you wouldn't be able to slide it under the seat, much less have the proper air space for the enclosure. Small box with an 8 or 10" in the back won't take up much space. Built the center console into a box, and I have worked on a couple systems where we built the area between the dash and the console into a box as well.
Old May 15, 2013 | 08:53 AM
h20_guy33's Avatar
h20_guy33
As stated, a box under second row wont work because the seats tumble. if you are willing to lose that feature, im sure a custom one could be built but air space would be very limited. most guys mount them in the barn doors, or in the hole for the spare tire.
Old May 15, 2013 | 10:34 AM
Archion's Avatar
Archion
Veteran: Marine Corps
I have a pair of 10's in a qlogic box strapped sideways on the rear cargo hooks in the back. If I need to put something big in, I throw the kill switch for the amp and ****** the box out. My amp is mounted under the 2nd drivers seat.
Old May 15, 2013 | 08:40 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
I installed 2 10" alpine type s in my barndoors, with the amp under pass 2nd row seat;-trucks.com/forums/picture.php?albumid=26272&pictureid=97603[/IMG]
Old May 15, 2013 | 08:51 PM
X-Hibition's Avatar
X-Hibition
I would vote for the barn doors to save the space. I try to use it all.
But then, I would never add a sub.
Old May 15, 2013 | 08:57 PM
Excursion123
How would the subs sound in the barn doors in the back. Would I still here them ok from the driver seat? Also there is a lot of stuff in those doors that I think would vibrate and rattle a lot.
Old May 15, 2013 | 09:12 PM
X-Hibition's Avatar
X-Hibition
Bass is omni-directional so having them in the rear is not an issue. You can fill the void with acoustic material, but you are dealing with a fiberglass door.
Old May 15, 2013 | 09:28 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
They are awesome rearview mirror shaking/ sounding I used the foil tape/rubber from home depot, lining the inside of the barn doors. Somebody on this fourm recommended this rubber instead of dynomat for sound proofing.
Old May 15, 2013 | 10:24 PM
04fivefour's Avatar
04fivefour
I've got mine in the barn door as well and is perfect and a fairly simple install. I've seen a couple guys that built a box that goes where the spare tire is. some pretty slick ideas.
openexcess
Jun 6, 2011 06:43 PM
cdraayer
Oct 9, 2005 10:53 PM
Andyman8282
30
Jun 19, 2004 01:39 PM
Togaduke
Mar 11, 2004 08:53 PM
daug85
Jul 19, 2003 05:27 PM
