Heater Rebuild
Old May 17, 2013 | 01:40 AM
Buzz44's Avatar
Buzz44
Originally Posted by nerksa
Wont open????
Old May 17, 2013 | 02:08 AM
The Masked Rider's Avatar
The Masked Rider
I don't have a pic (diagram) of routing of the heater lines and fluid travel through the motor but I'm sure you could find it on line.
The 'pressure side of the heater hose lines is the one coming off the intake manifold. The return line from the heater core goes to the water pump. The heater shut off valve must be in the heater hose line coming off the intake manifold.
On a side note: I remember reading an article in a tech manual many yrs ago, that said another reason besides getting the hottest coolent to the cab heater core,,, having the valve on the pressure side coming off the intake manifold ALSO will maintain a more even heat control in the intake manifold for fuel vaporization. If I recall correctly, this is the idea: IF the shut off valve was in the return heater hose going into the intake manifold, constant intake manifold heat would vary too much when the cab heater/fan was operating. Sounds logical to me....
Old May 17, 2013 | 02:10 PM
nerksa's Avatar
nerksa
Heater rebuild
I now see the cables are not
Connected and no valve exists under the hood.
Old May 18, 2013 | 03:03 AM
The Masked Rider
Here ya go. Autozone, 'Everco' heater control valve. #5851. $19.99 +tax. I just asked the guy for one for both my 65 & 66 - Everco # was the same. I believe it might also be listed 61-66 or later. Don't remember what he said. I had the OEM 'metal' one leak twice on each truck, SO, enough was enough. The newer one is made from ABS, it looks like, maybe - who knows - don't care. I've heard from others they have had good luck with them.
If you just MUST need the factory one, Ford dealers have them. More $, out dated part IMO.
Maybe someone that has the stock cable type in place can measure how far out from the firewall the hose needs to be cut. I'm going to be out of town and don't really want to pull the cover off. Sorry.
Old May 18, 2013 | 05:57 AM
nerksa's Avatar
nerksa
1966 Ford F 250 4x4
[IMG]i.imgur.com/43midmk.jpg[/IMG]
Old May 18, 2013 | 07:32 AM
nerksa's Avatar
nerksa
heater rebuild
Old May 18, 2013 | 07:50 AM
nerksa's Avatar
nerksa
heater rebuild
https://www.ford-trucks.com/forums/p...ctureid=130285
Picture of 1966 Ford F250 4x4
Old May 18, 2013 | 07:54 AM
nerksa's Avatar
nerksa
Heater Rebuild
Sorry to clutter up the forum with failed picture post attempts. finally got it figured out. will post more in future.
Old May 19, 2013 | 11:43 AM
nerksa's Avatar
nerksa
Radiator is shot. What do I need to know about ordering a new one and where do you recommend I look? Thanks for the great input.
Old May 19, 2013 | 03:51 PM
The Masked Rider
If the radiator is indeed the oem one that belongs there,,, I would have that one recored instead of having to drill new holes to fit a different one that doesn't belong there. JMO
Old May 19, 2013 | 05:01 PM
nerksa's Avatar
nerksa
Posted some pics in album under " nerksa"
njdevil77
Mar 28, 2018 08:16 PM
rneithammer
Nov 19, 2014 01:04 PM
Glen Murphy
1997 - 2003 F150
Aug 14, 2004 03:11 AM
DJ Rosa
Nov 22, 2003 06:03 AM
shack
Feb 9, 2003 08:40 PM
