Interior Trim
Old May 13, 2013 | 05:14 PM
Lockheed T-33's Avatar
Lockheed T-33
Interior Trim
I'm restoring my 1995 F-150 and noticed the plastic A-pillar covers were cracked at the bottom screw hole and causing a rattle. I have the rest of the truck looking good and this is bugging me. Any ideas? Does anyone reproduce these???
Old May 13, 2013 | 05:52 PM
nix4x4's Avatar
nix4x4
I had the same problem on mine. Very annoying...
I took a small washer and put in between the screw and the hole.
Tightened it up and rattles stopped.
Old May 13, 2013 | 06:32 PM
SideWinder4.9l's Avatar
SideWinder4.9l
I had the same issue. I simply pulled the parts, and used a pencil style soldering iron to melt the pieces back together, from the back.
Can't even tell it was broken.
Old May 13, 2013 | 07:40 PM
nix4x4's Avatar
nix4x4
Solder plastic?? Never knew... Hmm
Old May 13, 2013 | 08:44 PM
SideWinder4.9l
Google Plastic Welding..
It's actually a very expensive/extensive thing, but using a regular soldering iron lets you meet the same end, with different (Cheaper) means.
Old May 13, 2013 | 09:49 PM
Lockheed T-33
Thanks guys!!!!
Old May 13, 2013 | 10:25 PM
BigBlockF350's Avatar
BigBlockF350
LMC carries the part I believe. You could also look in a salvage yard.
I also agree that melting it back together from the back should solve the rattle.
Old May 13, 2013 | 10:45 PM
Lockheed T-33
I think I see them at LMC. Can't read it on my iPad. I'll look tomorrow at work. Thanks.
TexasGuy001
Dec 26, 2016 05:44 PM
fishnative
Dec 18, 2012 06:55 AM
dyingtolive
Jan 26, 2011 09:14 PM
mnalf3215
Appearance & Dress-Up
Jul 22, 2007 10:12 AM
Wakeboarder141
1978 - 1996 Big Bronco
Jul 11, 2003 03:57 PM
