Code p0402 after new EGR
Old May 12, 2013 | 08:16 PM
HzrInAz's Avatar
HzrInAz
I replaced my EGR, as I was told it was bad. It wasn't long before the CEL came on again with the same code. I was also told I had a bad injector. COuld this trigger that code? What else could it be? I also saw that AFE cold air intakes can trigger this? I have had that for many thousands of miles though, and no issue before. Any help is appreciated. Thanks.
2006 F250 6.0L Auto Banks tuner, Banks Exhaust AFE COld Air Intake
Old May 12, 2013 | 08:30 PM
bismic's Avatar
bismic
P0402 can be from your aftermarket intake.
Old May 12, 2013 | 08:53 PM
HzrInAz's Avatar
HzrInAz
Can it randomly appear like that after 50,000 miles or so with no code? Thanks
Old May 12, 2013 | 08:57 PM
bismic's Avatar
bismic
Don't know - maybe a Tech can/will jump in.
edit -
you could try cleaning your MAF sensor.
Old May 12, 2013 | 09:24 PM
cheezit's Avatar
cheezit
yes, normally do from a bad or dirty maf. i also had one installed facing wrong way cause it
Old May 12, 2013 | 09:28 PM
HzrInAz's Avatar
HzrInAz
Ah, so a bad maf can cause that too? How do you intall a maf the wrong direction?
Old May 13, 2013 | 05:29 PM
cheezit's Avatar
cheezit
being a dumba$$... no really there is an arrow for direction of ari flow as the sample chamber in the maf has to be pointing towards incomming air.
been there seen that trick before. took me a little while to find it
Old May 14, 2013 | 11:56 AM
HzrInAz's Avatar
HzrInAz
Ah, I can see that now. I cleaned the MAF and still have a CEL. Maybe it doesnt reset, so I will disconnect the battery and try that. Still seems low on power though. Kinda frustrating trying to figure out why. I appreciate the help.
Old May 14, 2013 | 03:52 PM
Edogsf350's Avatar
Edogsf350
Sorry to hi jack! Sohouldnt the arrow be pointing with the air flow?
Old May 14, 2013 | 04:00 PM
HzrInAz's Avatar
HzrInAz
There is an arrow pointing the direction yes.
So, I replaced the MAP sensor yesterday,because my brother broke it plugging my tuner back in. Also cleaned the MAF sensor. Truck is back to running awesome again with great throttle response....but, now I get a P0237 code...low turbo boost sensor circuit, which mentions the MAP also. This is a new one. My P0402 is gone though. Anyone?
Old May 14, 2013 | 05:11 PM
cheezit's Avatar
cheezit
thats what i said
tjschmidt1986
May 25, 2020 08:51 AM
Josh Lee Ponish
1997 - 2003 F150
Jul 24, 2016 07:55 PM
amd_038
Sep 8, 2011 11:37 AM
