Sponsored by: Auxito
Strange EGR problem help !!
Old Jul 22, 2016 | 06:03 PM
Josh Lee Ponish's Avatar
Josh Lee Ponish
Hello guys I have a stumper here. I have a 1997 Ford F150 with a 4.6 V8 it has been having EGR problems I forget what the code is exactly but it's something like insufficient EGR recirculation or something like that but anyway I have clean the upper air intake clean the EGR replace the tube going down to the header and replaced the sensor and I still get this damn code. now what I notice it seems the code peers only when the truck is idling and slow traffic any thoughts of what this could be. I'm guessing it's probably something else that's coming up as this code any thoughts would be appreciated.
Old Jul 22, 2016 | 07:55 PM
TruckinAL's Avatar
TruckinAL
What code is it ? I'm guessing PO-401 ?
Old Jul 22, 2016 | 11:28 PM
Bluegrass 7's Avatar
Bluegrass 7
You must offer the code or it's just guessing.
An EGR code does not come and go with engine speed because it is a static program test done two times at each drive cycle.
If a diagnostic failure if found it sets a code and does not go away until repaired.
Do not try to interpret a code unless your familiar with the systems.
It often causes confusion.
Good luck.
Old Jul 24, 2016 | 07:55 PM
Josh Lee Ponish
PO-401
I'm guessing it has to do something with the vacuum solenoid I did some internet searching and they're saying that it's probably that but the situation they are describing just not quite fit what's going on with mine could it be possible that the EGR diaphragm might be bad
davenpt
2004 - 2008 F150
21
Jul 7, 2014 01:33 PM
daw1264
1997 - 2003 F150
Feb 7, 2002 07:30 PM
