Ok, First a little background. I am building up a ford 9" to swap into my 90 bronco that I blew the stock 8.8 differential up in. I am jjust about done with the set-up and pressed the axle bearing onto the first shaft and tried installing it, when I realized that I put the bearing on backwards.
Well, the only way that I know of to remove and turn the bearing around involves cracking the retainer ring and pressing it off. Now the problem, I can't find anyone who caries just the retainer ring, or even has a part number for it, without buying the whole set. I got it with a Timken Set 20 but really don't want to spend the 30 + shipping on setup I don't need all of. So far Summit said that if I call Monday that they will call up Timken direct but does anyone else have any other ideas in the mean time?
Ball bearing also used in these vehicles. The retainer is different (2 7/16" O.D. x 1 1/2" I.D.).
September 1993: Riding elevator at Century City medical building, Tell (Sam Elliott) stepped in at 3rd floor, was wearing the exact same clothes as I.
Lucchese shirt, Levi's, Lama snakeskin boots. 'Course, he got all the attention, one gal kissed him, saying 'you're my favorite actor.'
Thanks for the help. For anyone looking for this info in the future, using your PN I was able to cross it over to a Timkin number R88128A, witch I found through Summit racing.
