1978 - 1996 Big Bronco
Alignment Specialist Needed
Old May 13, 2013 | 07:19 AM
DancoMotors's Avatar
DancoMotors
Exclamation Alignment Specialist Needed
I have an 84 Bronco in my shop that needs to have the caster and camber tweak. I have adjustable bushings installed, but need to double check myself and ensure that I have the right specs. I really need to talk to someone here that's aligned a lot of these and knows how to measure for the alignment specs.
what I did was measure ride height up front between the bottom of the spring perch and the top of the axle housing. I got 4" on the driver side and 4 1/2" on the passenger side (because its a split beam front end and the housings are different shapes on both sides) so i averaged them together to get 4 1/4". My info says that for that ride height, the camber specs are 1.50 degrees +- .75 and caster specs are 4.50 degrees +- 1.0. but that just seems so far out so i wanna be sure. the truck is supposedly stock height, but has taller tires on it.
am i missing something here? any help would be appreciated.
Old May 13, 2013 | 10:40 AM
Kemicalburns's Avatar
Kemicalburns
to be honest why not go to an alignment shop, they have the proper tools and equipment to get the job done correctly. if you can find a Firestone location they offer lifetime alignments which are a great investment for our bronco's.
Old May 14, 2013 | 07:14 AM
DancoMotors
i have my own shop. this is a customers vehicle. i just haven't done many of these trucks so I'm trying to learn. i have a hunter alignment machine and all the proper tools to do the job. I'm just questioning the specs and how i know if i'm using the right specs for the ride height of this truck.
Old May 14, 2013 | 09:33 AM
Kemicalburns
well take good look at the axle pivot bushings and the radius arm bushings, if these are shot you wont get the front end to align properly. sorry i dont have any specs for you, i can try and dig up my most recent alignment sheet to give you some reference.
pwjackson42
Jun 24, 2014 02:43 PM
DancoMotors
May 21, 2013 09:31 AM
dstruble
Apr 24, 2006 12:15 PM
Phideaux
Aug 23, 2004 08:49 AM
broncr
Dec 6, 2003 05:56 PM
