460 build suggestions?
Old May 12, 2013 | 04:22 PM
Chris Guthro's Avatar
Chris Guthro
What would you guys suggest i do with my 76 460 that im putting in my 84 2wd long box with a c6 and 3:50 9 inch limited slip? The bottom end needs a complete gone through since its been sitting so what would u guys do for a mild street engine? And will snall block c6 internals bolt all in my big block casing?
Old May 12, 2013 | 11:31 PM
85e150's Avatar
85e150
Serving suggestions, some have been critical of these, but the bottom line is more in, more out, squeeze it harder and rev it higher:
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
Old May 13, 2013 | 10:31 AM
mark a.'s Avatar
mark a.
Yes, small block C6 internal parts will interchange with a tall bolt patern C6. The most important thing to do with the 460 is get the pistons up to deck height. If you don't have a lot of money, get a '88-'93 FI piston set. They have a much smaller dish and will keep the compression at a reasonable ratio with D3 heads. You will also have to get the block's deck milled as close to zero as you can get it and get it balanced. Do a lot of work in the ex ports of the D3 heads you probably have. Grind the smog bump down and blend the seats in, mill them to 95cc and you will still have a motor that can run on 89 octane with a little distributor & carb. tuning.
Old May 13, 2013 | 02:04 PM
Chris Guthro
What compression ratio would one expect out of the d3 and fuel injection pistons? Or is it cheaper buying a set of flat tops? What's a good distributor and ignition to buy for cheap money that will get th job done
Old May 13, 2013 | 03:17 PM
Chris Guthro
What's a good street cam and intake combination too?
Old May 14, 2013 | 09:37 AM
mark a.'s Avatar
mark a.
If you aren't going to race it hard cast pistons will hold up fine. With the FI pistons you should end up somewhere around 9.2-9.5 depending on all things.The cost from a stock replacement FI piston set to a good set of forged is going to be (just off the top of my head) at least $250 or more. You would just have to shop around. Watch Ebay like a hawk, you never know if someone got stuck with a set they can't use.
You really can't select a cam untill you get your figures turned into facts. The best manifold is the Edelbrock air gap right behind that is the Weiand 8012.
Old May 15, 2013 | 06:53 PM
Chris Guthro
So can you order just the fuel injected pistons, because the rebuild kit for a fuel injected 460 would be a lot different than one for the 76, u think a performer is the best intake for my build?
Old May 19, 2013 | 09:03 AM
mark a.'s Avatar
mark a.
I've got a cupple sets of FI pistons over the years off ebay, payed $80 for one set, almost felt guilty . Personally I would only consider the air gap or the 8012 imo the Performer isn't much better than a stock manifold.
Old May 30, 2013 | 11:01 AM
Chris Guthro
is the torker 2 a good intake? i have a guy selling a complete 429 with a torker 2 dove heads for 500 bucks. is this a decent deal?
Justin Braun
Jan 3, 2017 06:54 PM
chaser460
Apr 30, 2013 08:28 PM
65f100CoryE.
Dec 19, 2006 01:02 PM
Blown 331
Jan 11, 2006 02:16 PM
timhoe
Jan 29, 2001 10:12 PM
