Cab stinky odour question
Old May 12, 2013 | 12:31 PM
Tim 79 F150's Avatar
Tim 79 F150
The last owner of my truck stored it in a barn each winter. To keep mice out of it they put moth ***** in the cab. Now it stinks of the month ***** and everyone comments about the bad stink. Besides replacing the seat and carpet any ideas on to get this stink out of the cab are appreciated.
Old May 12, 2013 | 12:43 PM
dlburch's Avatar
dlburch
I would remove the seat and carpeting and set it out in the sun for as long as it takes...leave the cab open and let it air out at the same time...then wipe down all the hard surfaces (where the moth ***** can't penetrate). If there is still a lingering odor, get some incense in your favorite scent and burn it in the ashtray...or other fireproof container...
Old May 12, 2013 | 01:08 PM
crazy96863's Avatar
crazy96863
Ditto on the previous response... Depending on the condition of your cab, this might be an opportunity & excuse to repaint the inside.
Old May 12, 2013 | 01:16 PM
fmc400's Avatar
fmc400
MSEE
My Galaxie had a pretty bad "old lady smell" that went away with lots of Febreze and leaving the windows open.
Old May 12, 2013 | 01:19 PM
cphoenix's Avatar
cphoenix
I would follow the advice above first. If you still have lingering odor after that, find a detailing shop and ask them to ozone treat your cab. It usually costs between $50.00 and $100.00.
Old May 12, 2013 | 01:22 PM
montana_highboy's Avatar
montana_highboy
That's why I don't date octogenarians.
Old May 12, 2013 | 02:17 PM
grinnergetter's Avatar
grinnergetter
The local waste company uses a product called "fresh cab" in the garbage trucks. I'm sure its just covering the smell up but it might be worth a try. Ace Hardware has it.
Old May 12, 2013 | 03:15 PM
whc8100's Avatar
whc8100
X2 on Fresh Cab works better than moth ***** to keep "Mickey" and friends out of you truck in storage. I use it in the camper too for the past three years and no mice.
Old May 12, 2013 | 07:36 PM
riverguideguy's Avatar
riverguideguy
i didnt understand it at first until i googled the octo thing lol
happy moms day to all your wifes and gfs
Old May 12, 2013 | 10:40 PM
montana_highboy
Yea, those big words can cause confusion, glad you got it figured out.
Old May 12, 2013 | 11:09 PM
tasboj's Avatar
tasboj
Sprinkle some baking soda on the carpet, or you could mix some with water and spray it inside the cab, hope this helps
Old May 13, 2013 | 09:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Meow: Heat "Johnny Cat" cat litter in a frying pan in the oven for one hour at 350 degrees, then place pan on floor of truck...use cardboard to protect carpet from burning.
Roll windows up, make sure doors are closed tight. Cat litter will absorb odors and moisture, also works to dehumidify gun safes.
Ozium available from autoparts stores, dealers usually spray it in A/C/heater/defroster vents to mask cigarette/cigar smoke. It works for awhile, but odors soon return.
Old May 13, 2013 | 10:59 AM
wilcam47's Avatar
wilcam47
white vinegar? or #5 and #6 on this link
How to Remove Mothball Odor from Clothing | eHow
Jarryd
17
Jan 16, 2015 09:28 AM
husky390
23
Jan 8, 2015 04:15 PM
jerem0621
Nov 11, 2013 09:21 PM
boucherbuilders
Dec 21, 2005 07:39 AM
Scraper
Jul 10, 2003 04:13 PM
