Speedo fix?
Old May 9, 2013 | 08:50 PM
Kuttawa07's Avatar
Kuttawa07
Speedo fix?
I have a 1975 f100 4x4 that the speedometer does not work. I just recently purchased the truck and when I first got it it would move some but was no where near accurate. Any help regarding the fix would be greatly appreciated.
Old May 9, 2013 | 09:30 PM
Harloff99's Avatar
Harloff99
Remove the instrument cluster and ensure the speedo cable is pushed all the way on to the speedometer. Also a good time to replace fix the cluster lighting.
Old May 9, 2013 | 09:35 PM
radar457's Avatar
radar457
Either a broken center cable or stripped plastic gear in trans case or cable end. Pull it out of the trans case and look at the gears. When you get the cable out of the trans case hook an electric drill to the steel center cable . Spin it left and watch odom. If it has a reading cable is good and plastic drive gear is trans is bad
Fellenz
Feb 3, 2014 11:36 AM
cabloom300
Jan 20, 2014 08:08 AM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
rw84f150
Nov 30, 2004 08:35 PM
Dustin_86
Nov 1, 2004 10:17 PM
