T-Case Shifter Help
Old May 9, 2013 | 09:14 PM
1975MudRat's Avatar
1975MudRat
T-Case Shifter Help
Well, I did a transmission swap, from a manual to an auto, and I am having trouble with the shifter. It is in a divorced set up and I put a 2wd C6 in it and there is no way to hook up the shifter lever. Like on the manual there is a hole to screw that bolt into but there isn't on the C6. Do any of you know what I can do? I know I can make a bracket but I wanna do it the right way. If any of you have a divorced T-case and a C6 can you post a pic of how your lever is.
Thank you, M
Old May 9, 2013 | 09:25 PM
co425's Avatar
co425
The tail shaft is shorter, has a fixed yoke and has a provision to mount the shifter. If remember ill take a photo of the one I have on Monday. Unless someone beats me to it.
Old May 9, 2013 | 09:41 PM
1975MudRat's Avatar
1975MudRat
Alright, I was told by a guy at NAPA (....bad information...) that there was a special bracket. I have no what he is talking about. Maybe he is right but I have no clue.
Old May 9, 2013 | 09:46 PM
co425's Avatar
co425
The shifter is welded into a bracket of sorts but it bolts right into the tail shaft.
Old May 9, 2013 | 09:47 PM
1975MudRat's Avatar
1975MudRat
Well there is no place for a bolt that big.
Old May 9, 2013 | 09:53 PM
co425's Avatar
co425
Yeah it's a big sucker I want to say the bushing is around 13/16".
Old May 9, 2013 | 09:56 PM
1975MudRat's Avatar
1975MudRat
Yea I have a bolt in the lever but there in no hole in the side of the tranny for something that big.
Old May 9, 2013 | 10:03 PM
co425's Avatar
co425
I found a thread. https://www.ford-trucks.com/forums/1...oration-4.html
About halfway down there are pics of a highboy c6 tailshaft.
Old May 9, 2013 | 10:06 PM
1975MudRat's Avatar
1975MudRat
Alright Thank you! I might have to crawl under it and look really really well. I could swear that there was no hole for it. If that is the case then what?
Old May 9, 2013 | 10:08 PM
co425's Avatar
co425
If its a standard 2wd c6 it won't only highboys have that tail shaft.
Old May 9, 2013 | 10:09 PM
1975MudRat's Avatar
1975MudRat
Alright well, then what will I have to do? Just make a bracket?
Old May 9, 2013 | 10:15 PM
co425's Avatar
co425
Either make a bracket or find a highboy C6. Those aren't too common. May get lucky at a pick n pull or equivalent.
Old May 9, 2013 | 10:17 PM
1975MudRat's Avatar
1975MudRat
Alright, well I think I'm gunna just jimmy rig something to hold it on lol. Thanks for your help! I really appreciate it! I'm out of reps for the day but I'll get ya when I can!
JoeKnows89
Nov 29, 2023 12:46 PM
bloodhound51
Nov 27, 2006 06:00 AM
Polkat
Oct 9, 2005 08:55 PM
fomoco3904
Mar 10, 2005 11:32 PM
dsc
Mar 14, 2002 06:22 PM
