Speedo Woes
Old Feb 3, 2014 | 10:36 AM
Fellenz's Avatar
Fellenz
Speedo Woes
Hey all..
Here's the story, In the midst and excitement of throwing the original trans. back into my truck ('65 short bed, 352) I failed to properly install the speedo cable. What I mean by that, is I plugged the speedo gear into the trans, but could not find a bolt to hold it securely..so of course I said "I'd do it later".
I took it out for a quick spin today and the speedo went to 0 going down the road. I thought ohh the cable just popped out. Upon inspection, the cable was still in the trans. I quickly traced the cable up ads far as I could, and didn't see anything out of the ordinary.
Do you guys have any ideas on this issue?
Old Feb 3, 2014 | 11:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
At the end of the cable is the speedometer DRIVEN gear.
If the bracket of the speedo cable is not bolted to the trans, the DRIVEN gear will not make contact with the speedometer DRIVE gear that is located on the output shaft.
Eharang
Apr 2, 2020 05:31 PM
PRUSue
Dec 11, 2011 12:06 PM
redf1001962
Nov 13, 2006 11:13 PM
rw84f150
Nov 30, 2004 08:35 PM
mchild
Sep 14, 2003 02:20 AM
