the upper joint to pitman arm has about 1 mm of lateral play,
anyways,
can I get the whole piece with upper and lower joint?
or does it only come as two separate pieces?
well I think I got the part # for a moog upper #DS80749
what is the moog part # for the lower part? cant seem to find it
and do I have the correct # for the upper?
btw--I really don't think it needs replace, but at inspection they failed it for this, they also failed my other truck for rusty exhaust clamps - seriously
If it has any noticeable play whatsoever it needs to be replaced. The play will get worse very quickly and eventually would separate causing loss of control. Bad engine parts may leave you stranded, but bad steering parts will kill you.
