Drag Link, Steering Arm?
Old Mar 18, 2014 | 06:54 PM
Tedster9's Avatar
Tedster9
Right now have the front end on jack stands, wheels off, soaking the brake hose and shock absorber hardware for replacement, etc.
Have kept up on lube orders and greasing zircs. Checking out the play on the steering components. Everything seems reasonably tight except, there is excessive play between the drag link ball joint at the curved drivers side steering arm (spindle arm?)
There is otherwise very little slop in the steering for a truck this age and the truck drives straight and true, tires wear evenly, etc. Can tolerate a little bit of slop but concerned obviously about safety. Who has stock replacement parts, not finding much for 64s at the usual sources. What's the best way to go about this, replacement or is there a kit? Would be willing to buy a front end rebuild kit, but the ball joint in picture would be a priority. Just not sure on some of the nomenclature, part numbers, who has a decent kit or whatever.
Thanks for the help, as always. Sent from my iPhone using IB AutoGroup
Old Mar 18, 2014 | 09:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Everything seems reasonably tight except, there is excessive play between the drag link ball joint at the curved drivers side steering arm.
1961/64 F100/250 2WD
C1UZ-3A130-A .. Right Tie Rod End-threads into reach rod...then connects to steering arm on spindle / Obsolete
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
FREESE MOTORS in Monticello IA has 3 = 319-465-3541.
WESLEY OBSOLETE PARTS in Liberty KY has 10 = 606-787-5293.
C1UZ-3A131-A .. Left Tie Rod End-threads into reach rod...then connects to steering arm on spindle / Obsolete
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
NOS PARTS LTD has 3.
FREESE MOTORS has 5.
WESLEY OBSOLETE PARTS has 7.
C1TT-3304-M .. Draglink / Obsolete
HAVEN FORD in Haven KS has 1 = 620-465-2252.
NOS PARTS LTD has 4.
GREEN SALES CO. has 28.
Old Mar 18, 2014 | 10:53 PM
Tedster9's Avatar
Tedster9
THANKS ND!! Always easier with the right part numbers.
Looking closer, (I think) it's the drag link specifically that is bad and needs replaced. it has a lot of play at the steering arm. Shouldn't be too hard to find, even locally. Can new ball studs and seals be installed? 50 years of dried grease makes it tough to figure. Just want this thing to be safe as it ever was.
Everything else is at work stoppage. The brake line fittings are just frozen on there, don't have the flare nut wrenches, the shock nuts won't budge. Tried PB blaster, etc. might take a couple days. Maybe some propane. Sent from my iPhone using IB AutoGroup
Old Mar 20, 2014 | 06:18 AM
NumberDummy
Ball joints (studs) are made as part of the draglink, cannot be replaced by themselves.
Old Mar 20, 2014 | 09:15 AM
Tedster9's Avatar
Tedster9
That's what I thought looking at the manual diagram. Everything seems tight except for that drag link. The end play has accelerated fast.
Decided to have a shop used in the past familiar with old school iron do the work. Won't be cheap but...
They will also unroll all new hard brake line, hoses, and make sure the rest of the brakes and steering linkage such are up to snuff. None of this stuff is above my skill level but put it all together, the aggravation factor can be high with.50 year old fasteners and the pros can do stuff a lot faster.
KC8QVO
6.7L Power Stroke Diesel
Aug 27, 2018 01:55 PM
Doucheatron
Jun 24, 2012 10:04 PM
Doucheatron
Jun 24, 2012 11:03 AM
BltFordTough
Apr 21, 2005 06:57 AM
ddurant
May 22, 2003 07:20 AM
