pitman arm worn out
Old May 16, 2006 | 10:30 AM
Truckmano5's Avatar
Truckmano5
pitman arm worn out
The ball joint on my pitman arm is worn out(I can wiggle the centerlink around and the steering has a good amount of play) and I'm trying to find out if I need to replace the center link when the pitman arm is replaced. I also need to know the cheapest place to buy a new pitman arm. Any help would be most appreciated
Old May 16, 2006 | 03:53 PM
1975Ford's Avatar
1975Ford
Is the ball joint on the pitman arm as one assembly?
I thought 1978 truck had the joint on the centerlink.
Most autopart stores carry the centerlink. Try our sponsor, AutoKrafters, Blue Oval Truck Parts, Jeff Bronco Graveyard, Mac's Antique Auto Parts, & National Parts Depot.
The Pitman arm can be found at National Parts Depot, Mac's Antique Auto Parts, and maybe Blue Oval Truck Parts.
Old May 17, 2006 | 10:50 AM
73Custom's Avatar
73Custom
I'm not sure about 4x4s but 2wd pitman arms are non wear parts - there are no joints to wear out. The joint is on the drag link and bolts to the pitman arm. Look at it closely, I bet you need a drag link. Most any parts store can get front end parts for you.
Marty
Old May 17, 2006 | 11:09 AM
Mil1ion's Avatar
Mil1ion
76/ 77 4x4's have pitman arms with ball joints
Here is an Illustration of parts ?
http://blueovaltruckparts.com/catalo...?cPath=194_204
He didn't state the year of truck or if it has Power Steering or not ....unfortunately.
Just partial information
Old May 18, 2006 | 08:38 AM
1975Ford's Avatar
1975Ford
Truckmano5, is it possible your truck has the 1976-1977 steering setup?
Old May 19, 2006 | 08:06 AM
Truckmano5's Avatar
Truckmano5
The truck is a 78 f250. It has the dual piston a lug setup, and its 2wd. I don't think it has earlier model steering components, but who knows.
Old May 19, 2006 | 10:49 PM
1975Ford's Avatar
1975Ford
Does the truck have power steering?
What is the dual lug setup?
Old May 23, 2006 | 03:41 PM
Truckmano5's Avatar
Truckmano5
the truck has power steering. I meant to say that it has 8 lugs per wheel, Dual piston calipers, and full floating rear axles. I am guessing it has a heavy duty setup.
Old May 23, 2006 | 04:06 PM
1975Ford's Avatar
1975Ford
The ball joint should be attached to the centerlink. The pitman arm does not have the ball joint.
