Carburetor Help
Old May 10, 2013 | 09:49 AM
miihere24's Avatar
miihere24
Carburetor Help
Being that I've been having issues accelerating - bogs down or dies at lower speeds when the gas pedal is pushed, I took a look at the carb. It says it's a "Uremco 7-7295A" re-manufactured in 2009.
It looks a little gunky to me and around the air filter housing it has a slight grease like film. I'm wondering if I should/could buy a rebuild kit, or just opt out for a different one.
If i replace the whole thing what other types of carbs should I look at?
I took a couple pics, but can't seem to upload them anywhere.
Old May 10, 2013 | 10:28 AM
JEFFFAFA's Avatar
JEFFFAFA
Send your pics to me at www.jeffreykurth@chapmanchoice.com. I'll scope 'em out.
Old May 10, 2013 | 01:15 PM
JEFFFAFA's Avatar
JEFFFAFA
Mandy,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
With the correct air filter it should close. Unless thestud that is in the middle of the carb is wrong and too short. Thatsticker is just the company which rebuilt it. That carb is a regular FordAutolite 2BBL. That plunger on the driver’s side of carb is supposed tobe up against the throttle lever instead of next to it. I also noticed on thosetwo molded in tubes with the holes on the top in front of the choke air hornwhat looks like dried up fuel trails. Those are the bowlvents. If there is fuel coming out of those vents that means your carbhas either a float or needle and seat problem. Since I see the chokeunloader behind the choke airhorn I am assuming you have a 1970 through 1974truck? If so, you can buy locally a replacement carb that is listedfor your application.<o></o>
<o> </o>
Jeff<o></o>
Old May 10, 2013 | 01:36 PM
miihere24's Avatar
miihere24
Fantastic help. I have a question about the air intake housing bit (the blue bit) and don't know technical terms to use, but I'd like to get rid of the blue bit that houses the air filter and replace it with the free standing open air intake filter.
Is that possible to do? If so what sort of parts would I need to buy/replace?
Old May 10, 2013 | 03:17 PM
JEFFFAFA's Avatar
JEFFFAFA
Just any standard universal Chrome aircleaner. The Ford 2BBL. is the same size as most 4BBL. carbs so it takes the same universal Chrome aircleaner.
Old May 10, 2013 | 03:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Bogging down, stumbling, hesitating from a dead stop and when accelerating at speed: defective accelerator pump, comes in carb kit or available by itself.
1970/74 2100 series 2V carbs have a choke diaphragm that mounts into the top of airhorn. All you can see of it, is its L shaped rod.
DOAZ-9J549-C (Motorcraft CM-1283) choke diaphragm does not come in carb kit, sold by itself.
D4AZ-9A586-A (replaced C2AZ-9A586-B) .. 2100 series Auto-Lite/Motorcraft Carburetor Kit (Motorcraft CT-499-D) / Available from Ford/autoparts stores.
Applications: ALL 1962/74 Passenger Cars/Trucks, 1966/74 Bronco's & 1969/74 Econolines.
nosehair
Oct 30, 2015 10:42 AM
Tugly
55
Jan 9, 2013 10:22 AM
TexinCali
Jan 5, 2013 09:35 PM
Tugly
26
Aug 1, 2012 10:08 PM
lwardell
Dec 3, 2004 10:08 AM
